Visitors: 148
Total: 148
29: Event Calendar
30: Home
39: Pictures
78: Event Calendar
85: Event Calendar
86: Home
90: Event Calendar
99: Event Calendar
106: Home
117: Event Calendar
JWHracing Baja
1 2 3 ... 9 10 11
Posted: Thu Sep 25, 2008 02:22 AM
hell, just put a plate from something else on it. and don't give the cops any reason to pull you over
wazhier
wazhier
Posted: Thu Sep 25, 2008 04:08 AM
we are going to do that. ive got about 4 plates with current tags from other things!
Posted: Thu Sep 25, 2008 04:14 AM
the actions of posters on this forum ,are not in anyway ,the responsablity of azbbaja,,or its staff,,so kids dont try this at home Laughing Laughing Laughing Laughing Laughing
Posted: Thu Sep 25, 2008 05:29 AM
sounds to me like a good way to have some fun. Laughing
man i wish mine was running so i could come play with you guys. Mad
neon99
neon99
Posted: Thu Sep 25, 2008 06:29 AM
Good job guys just get us all in trouble why dont ya !! James looks like ya got some more paint on the driver side also !!!
Posted: Thu Sep 25, 2008 06:34 AM
yeah, its getting there. i have more sanding to do on the front end then i'll prime and paint it. the roof is just gonna go primered for a while cause it has a lot of body work to be done to it.
its really just piddly stuff that needs to be done to get it driving. hopefully i can get it done in time to take it to the Foddrill show.
1970_baja
1970_baja
Posted: Thu Sep 25, 2008 06:56 AM
i really like the aluminum fenders. i think i might do that to my bug
Posted: Thu Sep 25, 2008 07:14 AM
its really not too hard. you just need a big enough sheet of aluminum to make both sides. some fenders you'll see will make the mounts all in one piece with the aluminum but some of those line up poorly. i made separate pieces of aluminum and bent them so they would be flat to the fender and flat to the original fender mounts.
i cut mine with a band-saw. so in some way or another you need to be able to cut the aluminum.
if you mount them the way i did, make your mounts and drill the holes then bolt them on. then lay your fender piece on top, mark the holes on the fender, drill them and bolt it on. you should have a pretty decent looking fender.
if you look my driver fender doesn't line up perfectly near the back. my passenger one is much better since i did that one after some experience.
if you'd like more pictures let me know.
Posted: Tue Sep 30, 2008 02:19 AM
UPDATE:
so the other day I purchased about 5 yards worth of fabric (4 grey, 1 blue) so that I could reapholster my stock rear seat and redo my door and quarter panels. The fabric I got actually exactly matches the fabric in my PRP suspension seats that are going in the front.
this is how the seat turned out:
I will take pictures once its in the car.
I also started on my rear bumper/engine cage. I will take pictures of it tomorrow after its finished.
Posted: Wed Oct 01, 2008 08:13 PM
here's my engine cage. this is just the basic concept is done. now I just have to make tabs for certain things (oil cooler, oil filter, lights, license plate, etc.)
its all .090 wall 1 1/2" tubing except for two pieces and the hoop I'm building which will hold the oil cooler.
neon99
neon99
Posted: Thu Oct 02, 2008 06:24 AM
Hey James what kinda of distributer are you running?
Posted: Thu Oct 02, 2008 07:25 AM
its actually an HEI distributor out of a Chevy Vega. Its some different stuff. Its actually the same distributor we're running in the vw buggy. It just gives more reliable spark and is a lot better with the turbo. You'd have to talk to my dad more about it, that's basically all i know. I just know it looks good. haha
Posted: Thu Oct 02, 2008 03:33 PM
Did you make provisions to remove the cage for things like and engine or trans change etc.
Posted: Thu Oct 02, 2008 05:34 PM
yes. it has tabs at each mounting point to the car. The two to the fire wall for the main tube is actually just a big square plate with four bolts and a plate on the other side (future roll cage point) And the other four spots are just 1.5 inch by 3 inch by quarter pieces of flat steel with the pipe welded at one end and a hole for a bolt at the other end.
Posted: Sun Oct 05, 2008 10:41 PM
UPDATE 10/5/08:
I got my tail lights mounted today.
this is what they look like:
I also did a lot of hooking up wires to the right locations. I filled the motor full of oil and put a battery in to try and start it.
It started, has oil pressure, (the dummy light works and shuts off) it seems like its running fine, and all of a sudden, oil's going everywhere! it ended up blowing the rubber gasket out of the oil filter. So now we need to put a pressure regulator on it. It made a nice mess too. But atleast I got to hear it run. Smile
1 2 3 ... 9 10 11
1568 mufasavnvmc 857433 Re: what did you do to...
285 MusicManiac 209744 Re: Baja sightings
Off-road event
1 wideopenmotorsports 398 Re: Baja run in March
 Mon Jan 08, 2018 05:09 PM
No new posts VW Volkswagen & Baja Bug General Discussion Considering buying a Baja Bug, but I have questions 4 AutomotiveDino 3327 Considering buying a B...
 Mon Jun 19, 2017 09:39 AM
daelan37 View latest post
