Visitors: 396
Total: 396
73: Event Calendar
122: Event Calendar
123: Event Calendar
144: Event Calendar
146: Event Calendar
150: Baja Forums
162: Baja Forums
164: Baja Forums
166: Baja Forums
168: Baja Forums
169: My Account
170: Baja Forums
172: Baja Forums
174: Event Calendar
176: Event Calendar
181: Baja Forums
183: Baja Forums
188: Baja Forums
190: AMAZON.com
192: Baja Forums
193: Baja Forums
195: Baja Forums
197: AMAZON.com
198: Baja Forums
199: Baja Forums
202: Baja Forums
203: My Account
204: My Account
205: Baja Forums
207: Baja Forums
208: AMAZON.com
209: AMAZON.com
210: AMAZON.com
211: Baja Forums
212: Baja Forums
213: AMAZON.com
214: Baja Forums
218: AMAZON.com
219: AMAZON.com
220: Baja Forums
221: AMAZON.com
222: Event Calendar
224: Baja Forums
225: AMAZON.com
226: Baja Forums
227: Baja Forums
228: Baja Forums
229: Baja Forums
230: Baja Forums
231: Baja Forums
232: Baja Forums
233: Baja Forums
234: Baja Forums
235: AMAZON.com
236: AMAZON.com
237: AMAZON.com
238: Pictures
239: AMAZON.com
240: Event Calendar
241: AMAZON.com
242: AMAZON.com
243: Baja Forums
244: AMAZON.com
245: AMAZON.com
246: AMAZON.com
247: AMAZON.com
248: AMAZON.com
249: AMAZON.com
250: AMAZON.com
251: AMAZON.com
252: My Account
253: AMAZON.com
254: AMAZON.com
255: AMAZON.com
256: AMAZON.com
257: AMAZON.com
258: AMAZON.com
259: AMAZON.com
260: Baja Forums
261: Baja Forums
262: Baja Forums
263: Baja Forums
264: Baja Forums
265: AMAZON.com
266: Baja Forums
267: Baja Forums
268: Baja Forums
269: AMAZON.com
270: AMAZON.com
271: Event Calendar
272: Baja Forums
273: Event Calendar
274: Baja Forums
275: Event Calendar
276: Baja Forums
277: Event Calendar
278: Event Calendar
279: Event Calendar
280: Event Calendar
281: Event Calendar
282: Event Calendar
283: Baja Forums
284: Baja Forums
285: AMAZON.com
286: AMAZON.com
287: AMAZON.com
288: AMAZON.com
289: AMAZON.com
290: AMAZON.com
291: AMAZON.com
292: AMAZON.com
293: AMAZON.com
294: AMAZON.com
295: AMAZON.com
296: AMAZON.com
297: AMAZON.com
298: AMAZON.com
299: Baja Forums
300: AMAZON.com
301: AMAZON.com
302: Baja Forums
303: AMAZON.com
304: AMAZON.com
305: Event Calendar
306: Baja Forums
307: Pictures
308: Pictures
309: AMAZON.com
310: AMAZON.com
311: AMAZON.com
312: AMAZON.com
313: Event Calendar
314: AMAZON.com
315: AMAZON.com
316: Baja Forums
317: AMAZON.com
318: AMAZON.com
319: AMAZON.com
320: Event Calendar
321: AMAZON.com
322: AMAZON.com
323: AMAZON.com
324: AMAZON.com
325: AMAZON.com
326: AMAZON.com
327: AMAZON.com
328: AMAZON.com
329: AMAZON.com
330: AMAZON.com
331: AMAZON.com
332: My Account
333: My Account
334: My Account
335: My Account
336: My Account
337: Baja Forums
338: My Account
339: My Account
340: My Account
341: My Account
342: My Account
343: Baja Forums
344: AMAZON.com
345: AMAZON.com
346: AMAZON.com
347: AMAZON.com
348: My Account
349: Baja Forums
350: Baja Forums
351: Baja Forums
352: AMAZON.com
353: AMAZON.com
354: AMAZON.com
355: Baja Forums
356: AMAZON.com
357: AMAZON.com
358: Event Calendar
359: AMAZON.com
360: Baja Forums
361: Baja Forums
362: Baja Forums
363: AMAZON.com
364: Pictures
365: Baja Forums
366: AMAZON.com
367: Baja Forums
368: AMAZON.com
369: AMAZON.com
370: My Account
371: Baja Forums
372: Pictures
373: AMAZON.com
374: AMAZON.com
375: Baja Forums
376: Pictures
377: Pictures
378: AMAZON.com
379: Baja Forums
380: Baja Forums
381: AMAZON.com
382: AMAZON.com
383: AMAZON.com
384: AMAZON.com
385: AMAZON.com
386: AMAZON.com
387: AMAZON.com
388: AMAZON.com
389: AMAZON.com
390: AMAZON.com
391: AMAZON.com
392: AMAZON.com
393: Event Calendar
394: Baja Forums
395: Baja Forums
396: Baja Forums
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- does'nt when warmed up, need help
cheapbeetle
cheapbeetle
Post Post subject: does'nt when warmed up, need help
Posted: Thu Sep 04, 2008 05:22 AM
i need some help, i'm a need member to azbaja and a new owner of a 1969 beetle, when my beetle (1600cc single port) is warmed up it does'nt seem to idle, it just wants to die. i have cleaned the carb but had no luck! any ideas anyone? Mad
cheap beetle
Post Post subject: Re: does'nt when warmed up, need help
Posted: Thu Sep 04, 2008 05:43 AM
Check the idle on the carb, adjust the carb if needed (leaner or richer) check the timing.
Thats all i got, i had similar problems with my 68 Dual Port, usually it's a quick Carb adjustment that solves the problem.
and WELCOME TO AZBAJA!
cheapbeetle
cheapbeetle
Posted: Fri Sep 05, 2008 03:00 AM
about how many turns on the air/fuel mixture screw?
cheap beetle
Posted: Fri Sep 05, 2008 05:10 AM
you have to find the right spot for it. keep messing with it. you will figure it out just remeber how many you went right or how many you went left. it just all depends.
Posted: Fri Sep 05, 2008 05:12 AM
just keep going till it starts running better, if it gets worse turn the screw the other way.
once you get it where you like it, drive it for about 5 min then check it again and make any adjustments needed.
GOOD LUCK Cool
cwick1989
cwick1989
Posted: Fri Sep 05, 2008 05:23 AM
If it runs til it gets warmed up the choke turns off then it dies maby an air leak or a vaccum leak, silanoid, unequal compresion in your cylinder.... but id make sure its not a bad ajustment 1st! alot of people start with 1-2.5 turns out.... and then just keep your hand on the trottle then adjust it til it idles... if it wont idle then its probly an air leak and if thats what it is take a can of carb cleaner, ether, etc.. (anything in a can that sprays) and then spray the joint and or where all gaskets are and if the engine revs thats where your leak is... (make sure you dont spray the distibutor or you might have a lil fire on your hands!)Ive been goin through the sae thing you are...
cheapbeetle
cheapbeetle
you really think thats the problem? like i said it runs fine cold until it gets warmed up then it just wont idle. like they say in the south throw me a bone...........lol
cheap beetle
cwick1989
cwick1989
Posted: Fri Sep 05, 2008 05:35 AM
If it runs til it gets warmed up the choke turns off then it dies maby an air leak or a vaccum leak, silanoid, unequal compresion in your cylinder.... but id make sure its not a bad ajustment 1st! alot of people start with 1-2.5 turns out.... and then just keep your hand on the trottle then adjust it til it idles... if it wont idle then its probly an air leak and if thats what it is take a can of carb cleaner, ether, etc.. (anything in a can that sprays) and then spray the joint and or where all gaskets are and if the engine revs thats where your leak is... (make sure you dont spray the distibutor or you might have a lil fire on your hands!)Ive been goin through the same thing you are... i feel your pain!
