Visitors: 133
Total: 133
05: My Account
41: Event Calendar
77: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- irs vs bug trans
irs vs bug trans
Post Post subject: irs vs bug trans
Posted: Wed Aug 13, 2008 02:29 AM
i have a random question kinda.
i was wondering why everyone goes to bus trans. and why not just keep a bug trans.
i know that the gearing ratio is different but you can change ratios in a bug also.
just thought i would ask.
Post Post subject: Re: irs vs bug trans
Posted: Wed Aug 13, 2008 03:24 AM
If you are running anything up to a mild 1835 you can run a bug trans uaually with no probs if you dont beat on it too hard. If you plan on beating it or putting a hi HP motor behind it you better think about a bus trans because it will hold up to the abuse/hp better.
Posted: Wed Aug 13, 2008 03:26 AM
but there is nothing special about of to much difference though.
inless your going to be beating the shit out of it then you would want to get a bus trans. then
Posted: Wed Aug 13, 2008 05:25 AM
My dad says its fairly easy to lose a gear in a bug trans (unless its rebuilt)
I know my reverse gear will be out in the next year. or more hopefully. Sometimes it doesnt like to go into reverse as easy, but it wont pop out.
DutchBug
DutchBug
Posted: Wed Aug 13, 2008 11:23 AM
In the Baja Bugs & Buggies book there is a topic on this, they have pics of both wich gives a good idear of the dimensions. Not that I have any experience on this but it looks stronger (bigger = stronger?)
Posted: Wed Aug 13, 2008 03:37 PM
yeah your kinda right
Posted: Wed Aug 13, 2008 10:26 PM
Well, there's really no "kinda" about it. IF the Type I (bug) transmissions were sufficient, VW would have put them in production Type IIs (buses), don't ya think? Since the trans in a bus is subject to more strain, mainly from pushing more weight around EVERY time you turn the key on, they (VW) determined that a Type I trans was inadequate for that application. Soooo, although you won't often hear me proclaiming to be absolutely correct about ANYthing, I'm very comfortable making this statement, which I feel is based on fact at this point- BUS TRANSMISSIONS ARE MORE DURABLE THAN BUG (IRS) TRANSMISSIONS.
Will a bug trans be enough for you? Try it and find out, because that's the only way you'll ever know for sure.
Thank you- I'll be here all week. Laughing
sandshark
sandshark
Posted: Wed Aug 13, 2008 11:15 PM
I'm glad you started this thread 333. I've been curious about some aspects of this after doing some online research. 1st, I believe one of the BIG differences is HYPOID R&P vs NON-HYPOID R&P, I believe the T2 is a hypoid R&P. Hypoid is inherently stronger because, regardles of the ratio, a hypoid R&P will always have more gear mesh at any time. Everything being beefier is the no-brainer part. However, Jake Raby's (who seems to have a superb reputation) MassIVe 4 site says they have T1 trannys ( & &#%^%$% torque biasing diffs too!!!$$$ ) to handle monster motors, and they're not too terribly expensive. I'd be interested in hearing some of the more knowledgable of you weigh in on this one. After all, if a T1 CAN be built to handle big torque, being lighter - & easier to mount in a Baja - is a big plus in my book. Zyla? Anybody?
Posted: Wed Aug 13, 2008 11:49 PM
yeah i agree it was just a question that i thought i would bring up.
Sample
Sample
Posted: Wed Aug 13, 2008 11:58 PM
Why don't you buy my baja, jump it and find out if the trans holds up to abuse? Very Happy
1966 Baja.
Posted: Thu Aug 14, 2008 02:15 AM
lol
yeah i know i thought you had a buyer
Sample
Sample
Posted: Thu Aug 14, 2008 04:11 AM
Nope, two more flaked out on me. Very Happy
donsbusbox
Brigadier General
Brigadier General
donsbusbox
Posted: Thu Aug 14, 2008 05:22 AM
The BUG ring gear is 6+" and the BUS ring gear is 8", the pinion shaft is larger in the BUS also, the case is stronger in the BUS but a gussett on the BUG works well also. The gearset (1st throught 4th) are the same in the BUS and the BUG, year for year, EXCEPT the 091 and 094 BUS trans where they went bigger on everything. Make sense?
more here: www.donsbusbox.com/pag...p?pageid=6
Don\'s Bus Box\r\nVW Trans Specialists\r\n602-670-0192
Posted: Thu Aug 14, 2008 06:28 AM
well my neighbor is a mechanic and he said that is the only big difference really.
also i think he said that you could change 4th to 3rd and 3rd to 4th
which will give more torge and increase speed
sample
could we meet like half way somewhere so i could check it out. im going to be in scottsdale on saturday morning.
Sample
Sample
Posted: Thu Aug 14, 2008 06:30 AM
Dan, Scottsdale is way out of both of our ways. I am east of you on the 60. Where in Chandler are you?
No new posts VW Volkswagen & Baja Bug General Discussion needed asap swing axle trans 5 Dirtjunkie 2715 needed asap swing axle...
 Fri Oct 12, 2012 06:10 AM
No new posts VW Volkswagen & Baja Bug General Discussion Changing over to 3-rib bus trans... maybe? 10 planenutz 5394 Changing over to 3-rib...
 Wed Jan 18, 2012 09:20 AM
planenutz View latest post
17 TwistedMetal 13185 Which trans with a 22r...
 Mon Dec 05, 2011 02:51 AM
chrispy56 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Instructions to install 002 trans. in 1969 1600 Baja?J 12 glenf 10401 Re: Instructions to in...
 Fri Apr 24, 2009 06:45 PM
DONT View latest post
No new posts VW Volkswagen & Baja Bug General Discussion trans adapter for 1.6 hyundai motor 1 trumpit 1824 Re: trans adapter for ...
 Wed Dec 17, 2008 06:03 PM
