Latest: Smokey4
Overall: 3593
Visitors: 123
Total: 123
16: Home
22: My Account
29: Pictures
30: Home
43: Pictures
45: Home
49: Pictures
80: Event Calendar
110: Home
116: My Account
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- im back, time to get to work on the bug!
shpuz
shpuz
Post Post subject: im back, time to get to work on the bug!
Posted: Fri Aug 08, 2008 05:55 AM
well im back in good ol' kansas and have already found another job, so its time to do some repairs on the bug, but i have some questions.
where do i hook up the transmission ground strap?
i have a ground wire running from one of the bolts that hold the engine to the trans, to the body. so would thta work as the ground strap, or do i still need to hook the other one up?
and last, would it be best if i just patch up the rust on the heater channels(on the outside, and lots of it), or just replace the whole thing?
let me know what you guys think.
Quote::
Post Post subject: Re: im back, time to get to work on the bug!
Posted: Fri Aug 08, 2008 06:11 PM
Traditionally the eng/ trans ground strap runs from the rear torsion bar trans mount to the transaxle. I hope I understood your question.
Just patching them is faster. At sometime they will need replacing.
Posted: Sat Aug 09, 2008 03:08 AM
Welcome back!
Depends on how cold it gets in Kansas whether you do the whole thing(heaater channel va. repair) or not, plus money and time. It can get pretty damn cold here in Va so I went for the whole shebang since the body was off the pan. Luckily only the one side was needed for mine.
Not sure about the ground strap. It's got me a wondering now. Since I went with a total wire job from Watsons. I dont know if I saw any thing in the kit for that. I would imagine a good braided strap from the tranny to the frame (torsion as already suggested) would be fine.
shpuz
shpuz
Posted: Sat Sep 06, 2008 07:17 AM
well, i got the ground stap on there, but now i dont even have power coming out of the coil. replaced the coil, and still the same thing. i am totaly stumped. i am about to break down and take it to a shop(wich i dont want to do). any advice would be welcome.
Posted: Sat Sep 06, 2008 02:36 PM
Grab an asistant this will take 5 minutes to diagnois. Do the points open and close? Is the gap set? You should have 12 volts at terminal 15 while cranking and with the key on. Terminal 1 should only have the green wire from the distributor going to it. (Exception would be a tach wire or electronic ignition wire.) You can turn the engine until the points close. With a small screwdriver with the tip taped you can open the points and see if you have spark with the key on.
Dirty point contacts, bad condenser, open in green condensor wire, broken braided ground wire in distributor are problems you could have. Since its been sitting a while I suspect corroded, dirty points. The Bentley manual for your year VW will be the best tool you will ever buy.
No new posts VW Volkswagen & Baja Bug General Discussion Engine Work 5 ghs215 2115 Re: Engine Work
 Mon Jan 08, 2018 01:59 AM
New User
2 Treeposter 2033 Time to let go....
 Wed Jun 21, 2017 11:23 PM
No new posts New Members New Memb. First time post 3 Maxxh2o 2879 New Memb. First time ...
 Tue May 27, 2014 10:32 AM
No new posts Projects and Builds It's Time! Summer Upgrades
17 Yummi 14208 Re: It's Time! Summer...
 Fri Nov 22, 2013 06:10 AM
Yummi View latest post
No new posts Projects and Builds It's about time... 3 Turbobaja 2786 It's about time...
 Fri Jan 25, 2013 04:07 PM
