Visitors: 140
Total: 140
76: Event Calendar
84: Event Calendar
103: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Spray on truck bed liner?
liftman_2002
liftman_2002
Post Post subject: Spray on truck bed liner?
Posted: Fri Aug 01, 2008 07:09 PM
I just restarted to restore my 69 Baja and was thinking about using a spray on truck bed liner for the paint. Has anyone done this?
SoCalBajas.com
Post Post subject: Re: Spray on truck bed liner?
Posted: Fri Aug 01, 2008 07:29 PM
My pan has herculiner on it. Doing the whole body would make it heavy, but durable. I prefer paint
liftman_2002
liftman_2002
Posted: Fri Aug 01, 2008 07:47 PM
How has it held up?
Posted: Sat Aug 02, 2008 12:04 AM
herculiner is great stuff
i wouldnt tink that it would go good for the body but if you do it for the pan then it is good. also it would and will make your car alot heavyer. and it probably wouldnt look to good either.
just use paint or rattle can ( joxs )
Posted: Sat Aug 02, 2008 02:13 AM
Line X 4 coats= 40 pounds and 2200.00
on hold baja build
"when I nod my head, HIT IT"
Posted: Sat Aug 02, 2008 05:20 AM
That's WILD! I had a red spray-in bedliner in my OBS diesel Ford, and it faded pretty bad. I hope that doesn't happen to this FJ. Cool though!
greenehoosier
greenehoosier
Posted: Sat Aug 02, 2008 01:38 PM
The bottom half of my Baja project is cheap Wal-Mart roll on bedliner. I used it on my Warrior a few years ago and loved it. Easy to touch up, wears well..
Posted: Sat Aug 02, 2008 04:59 PM
The herculiner is good stuff and the price is fair. We have done several pans with it, and one we lines the whole inside of the car. The only caustion I will give you is once you have bedlinered the outsied, its next to imposible to get off. So if you are going to do it make sure you are ready for it to be permanent.
Neander
Neander
Posted: Sat Aug 02, 2008 08:04 PM
i was thinking of lining my whole car too, but now i might just do the bottom half of the car and the pan for sure. what spots do you have to make sure NOT to hit with the liner that might cause problems later? and can you paint over the liner to put stripes or designs over it?
greenehoosier
greenehoosier
Posted: Sat Aug 02, 2008 08:15 PM
For me, the idea of getting it off is not much of a problem. I can replace the doors from my personal stash and the fenders were junkyard dogs that are cheap to replace. That only leaves two areas with liner on it. The front and rear quarters can be had off with a sander in an hour or two (lots of heavy grit paper...).
I have never tried to paint over it with a contrasting color. I use Rustoleum semi-gloss black over the bedliner to even the tone out a bit. That takes about 3 cans for the portion you see.... The only things you shoud be careful of are the edges-they can accumulate a bit too much if you tend to stop there. The door handle are should be light too, because it can be hard to get the handles to fit. Stay away from the bolt holes, it is tough to get the bolts in if some seeps in there.
Neander
Neander
Posted: Sun Aug 03, 2008 04:17 AM
alright then thanks
Posted: Sun Aug 03, 2008 04:41 AM
I saw too buses this weekend that had the exterior done in Hippo brand bedliner. It has a UV protector and can be tinted. The guys said it runs about $175 for a gallon, and can be purchased and mixed at carquest. He said the bus took 6 gallons. Looked cool, but thats about $1200....
liftman_2002
liftman_2002
Posted: Mon Aug 04, 2008 06:44 AM
I think I'm going to go with the lower half and the pan in side out.
little_penny
little_penny
Posted: Sun Sep 21, 2008 01:22 AM
Here is a pick of mine.
Rhino inside and out.
[img]http://i116.photobucket.com/albums/o12/little_penny02/IMG_4543.jpg[\img]
little_penny
little_penny
Posted: Sun Sep 21, 2008 01:28 AM
Sorry heres the pic
No new posts VW Volkswagen & Baja Bug General Discussion *** STOLEN White 2004 Ford F250 Truck ***
*** Stolen White 2004 Ford F250 Truck ***
7 Conundrum 3264 *** STOLEN White 2004 ...
 Sat Dec 19, 2015 08:36 PM
No new posts VW Volkswagen & Baja Bug General Discussion Travel- Delivery- Open trailers or truck beds?
Parts
0 catchbats 1881 Travel- Delivery- Open...
 Mon Oct 25, 2010 06:06 PM
catchbats View latest post
No new posts VW Volkswagen & Baja Bug General Discussion beer liner 5 luhrman645 3103 beer liner
 Wed Aug 25, 2010 12:04 AM
luhrman645 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion [ Poll ] buggy converted to a truck 4 lvrider 2917 Re: buggy converted to...
 Tue Mar 09, 2010 10:09 PM
No new posts VW Volkswagen & Baja Bug General Discussion '61 BUG TRUCK 12 Preston 8199 Re: '61 BUG TRUCK
 Wed Aug 06, 2008 12:46 AM
danjones333 View latest post
