Visitors: 122
Total: 122
08: Home
42: Event Calendar
54: Home
55: My Account
86: Event Calendar
108: Event Calendar
110: Event Calendar
117: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Stock CV joint limits/1x1 or stockx1 arms?
ditch68
ditch68
Post Post subject: Stock CV joint limits/1x1 or stockx1 arms?
Posted: Sun Jun 08, 2008 04:14 AM
I went out today for some offroading after drill, and it is now patently apparent to me that I am driving at and beyond the limits of my suspension. I regularly bottom the rear, and the front. I am running dual Gas-Adjust shocks in the rear with a stock (plus one) IRS shockmount setup. Cut and turned stock LP beam up front.
I will be adding one more spline of preload to the bars next weekend, but I think I need to do some modification.
As it is now, the trailing arms themselves are bottoming hard on the shock/body towers. I have no stock snubber. I need to put a urethane snubber on there...
My question is, can I run my perfectly OK stock CV joints and stock length axles with 1x1 or stock x 1 boxed arms? I think a 3 x 3 setup is a little bit of a financial reach, but I wnt to continue driving harder like I am. I am thrashing my poor trailing arms right now.
Any experience with this?
Jeff
I will also do the warrior 6" wider front with 10" towers soon.
Beer is NOT AN OPTION....
(meaning not optional)
1971 Type 3 Squareback FI/AT
Post Post subject: Re: Stock CV joint limits/1x1 or stockx1 arms?
Posted: Sun Jun 08, 2008 01:54 PM
thats the problem alot of us have. the only way to get better suspension is to pay for coil overs and lose the torsion bars front and rear...$$$ and or go a-arm... Sad
Posted: Sun Jun 08, 2008 07:31 PM
What size torsion bars are you using in the rear? If you are not already... you could use the longer bars and go up to a 27 or 28mm dia.
ditch68
ditch68
Posted: Mon Jun 09, 2008 01:22 AM
As far as I know, they are stock bars. When I add some preload I will take a look.
I was considering boxed arms, as I am reasonably sure I am bending my arms. I don't mind going with stock x 1 arms (Good enough for class 5 /1600...) but will stock CVs be OK?
You guys are both right. I should just accept the hard fact that speed costs money.
How fast do I want to spend??
I hit 65mph in the desert yesterday....whoopsie. That sounds like $$$$$.
Smile
1 suburbangorilla 3293 CONVERTING '71 STOCK B...
 Wed Apr 01, 2015 11:51 AM
No new posts VW Volkswagen & Baja Bug General Discussion Wheel travel stock vs. 3x3 6 ghettodish 6831 Wheel travel stock vs....
 Tue Jan 31, 2012 02:57 AM
No new posts VW Volkswagen & Baja Bug General Discussion Does any one local to Chandler AZ stock 7x15 tires? 3 tobiism 8734 Does any one local to ...
 Wed Dec 14, 2011 02:46 AM
No new posts VW Volkswagen & Baja Bug General Discussion rack & pinion w/stock fuel tank 0 ghettodish 1873 rack & pinion w/stock ...
 Wed Nov 09, 2011 07:44 AM
ghettodish View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Wide Ball Joint front end? 5 Darn_Near 7545 Wide Ball Joint front ...
 Wed Sep 07, 2011 08:12 AM
Darn_Near View latest post
