Latest: BlackIrish05009
Overall: 3574
Visitors: 143
Total: 143
20: Event Calendar
21: Event Calendar
38: Event Calendar
54: Event Calendar
58: My Account
71: Event Calendar
95: Event Calendar
112: Event Calendar
118: Event Calendar
119: Pictures
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Tire sizes?
Tire sizes?
Post Post subject: Tire sizes?
Posted: Wed Jun 18, 2008 11:30 PM
Ok guys, I know this is hidden some where on here but with the last week and a half of stuff related work, MY BRAIN IS FRIED.
I got my new wheels today (WOO-HOO!) but I'm a little concerned about the size. So I temp mounted just to see how they look. Damn goo I might say but what I'm concerned about is clearance.
The rims measure: Ft. 7"w 15"d, rear. 10"w 15"d
On the front, I measured from the rim area where the tire bead would sit to the nearest object that may contact the tire (vise-versa) I measured 7" from there to the top of where the tire tread would be (this with the wheel turned out, measured the inside to..), leaving 1/4 inch of clearance. The rear I measure 7 3/4" to the torsion bar (closest object to wheel)
From what I've read, the front tire should be 178/106 15 and the rear should be 254/196 15 if I did my calculations right.
When I try to use those sizes to look for tires, aint no such animals.
90xjlimited4x4
90xjlimited4x4
Post Post subject: Re: Tire sizes?
Posted: Thu Jun 19, 2008 12:14 AM
measure from the center of the hub to the nearest object double that measurement! subtract a half of an inch thats the largest tire size you can run....
Posted: Thu Jun 19, 2008 01:23 AM
im running 205/70r15 up front and 245/75r15s
Which is roughly (educated guess) 27" and 31"!
Found a tire converter and its 26.5" and 30.6" without rubbing!
Posted: Thu Jun 19, 2008 03:11 AM
WaBaja,
What width rims you runnin? Also, are you runnin IRS with the long torsions?
90, yep. Did that. Rear: center hub to torsion/springplate 15.5 " By what you said and my calculations, I can run 30.5" in the rear. Front: with the front of the wheel turned out, I measured on the inside 15" to the body channel. Appears to be the closest object. 29.5 " tires would be my guess.
I'm not looking for the biggest tires I can fit, just ones that fit these rims but have enough clearance.
Thanks fella's
Posted: Thu Jun 19, 2008 04:05 AM
Im not sure on rim size. I got a swing axle. You can only run true 31"s on long torsion I believe. Im not 100% sure, I just remember reading it.
90xjlimited4x4
90xjlimited4x4
Posted: Thu Jun 19, 2008 04:23 AM
ya a 31 is the biggest you will fit in the rear on the front oyu can probally squeeze a 7.00 15 very tall skinny tire its approx a 30x6x15 this all depends on the hight of the car too also what fenders...ect if you can barrow a friends wheel and check fitment while on the ground...
No new posts VW Volkswagen & Baja Bug General Discussion Tire track width 4 cperry2704 1918 Tire track width
 Fri Dec 02, 2016 06:16 PM
No new posts VW Volkswagen & Baja Bug General Discussion Who's got a buddy at discout tire? 2 Ejbbal21 2469 Re: Who's got a buddy ...
 Sun Mar 25, 2012 02:43 AM
Ejbbal21 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion WATED: Wide 5 Aluminim Rim and Tire
Something like a Center line
1 DEDSLED2012 2257 WATED: Wide 5 Aluminim...
 Tue Mar 13, 2012 07:52 AM
No new posts VW Volkswagen & Baja Bug General Discussion NEWB with class 11 tire question
class 11 guys
2 icebox 6541 NEWB with class 11 tir...
 Fri Jan 06, 2012 05:38 AM
No new posts VW Volkswagen & Baja Bug General Discussion Need to borrow (2) 4-lug sotck wheel & tire set 2 fabinc 2441 Need to borrow (2) 4-l...
 Tue Jun 23, 2009 10:23 PM
danjones333 View latest post
