Visitors: 122
Total: 122
04: Garage
05: Home
21: Garage
29: Garage
35: Garage
36: Garage
41: Garage
43: Garage
54: Garage
61: Garage
77: Event Calendar
89: Garage
95: Garage
97: Garage
103: Garage
111: Garage
120: Garage
Baja Forums -:- AzBaja.com Members -:- Projects and Builds -:- MeanGreen's Baja Build.
meangreen
meangreen
Post Post subject: Re: MeanGreen's Baja Build.
Posted: Thu Jun 19, 2008 03:58 AM
some progress,i think i like the way this looks,i have a electric fan im gunna run under it,mind u this is a 4.3 radiator and its a 2.5 engine the added size should make up for low air flow
what yall think ?
Posted: Thu Jun 19, 2008 04:47 AM
looks bitchin
Posted: Thu Jun 19, 2008 04:49 AM
Looks good man... Keep them pics com'in Wink
meangreen
meangreen
Posted: Thu Jun 19, 2008 05:23 AM
finally finished the rebuild on the 2.5,it didn really need it but i figured do it now in the bug buildup rather than it blow up on me on the trails.....i plan on running a carb on it for a while,until i can order the "megasquirt" cpu i am wanting...i have a 260h comp cam,custom tune port inj. that i am building that uses a ls1 throttle body,and venom injecterz... and a header that will go on with the megasquirt,i am hop'n to have the mega. installed and programmed by mid october but we will just have to see.i am in the mist of building a custom dash that will house silver autometer gauges-speed-o,tack,water,oil,fuel,u no the works....this dash will run down into a console that has CUP HOLDER'S !!!!!! i am trying to decide wich rout i am gunna go with the a/c tho becuz this will be my daily driver i want the works...i just caint decide if i was run a rebuilt factory option a/c under dahs setup or just buildmy own,any idea's ?
Posted: Thu Jun 19, 2008 06:07 AM
you got any pictures of the baja in yerr avatar?
Posted: Thu Jun 19, 2008 06:22 AM
Make some side scoops out of diamondplate. WOULD BE BADASS!
meangreen
meangreen
Posted: Thu Jun 19, 2008 11:40 PM
i dont have any pics of the green bug on this comp,my laptop has them all,and it is in the shop.....$$$$$ i can do all kinds of triky stuff with dimond plate cuz i get it FREE from a buddy usually in 1ft.x5ft. sections
Posted: Fri Jun 20, 2008 12:36 AM
Side scoops over your body vents by side windows are trick.
And wanna send me some DP? lol!
GOTDUNES
GOTDUNES
Posted: Fri Jun 20, 2008 05:54 AM
what yall think ?
Looks great ,
however I'm concerned with the amount of air in the system. Have you thought about increasing the angle of the rad? It seems to me you will have a problem with flow. Do you have an overflow bottle? If so, the level of coolant must be level to the height of the top of the rad.
Just a concern. Question
meangreen
meangreen
Posted: Fri Jun 20, 2008 08:01 PM
well this is not final as far as placement is consernd its just to get some feedback from ya'll...as far as flow issues are consernd when i cap of the bottem radiator hole,and fill it with water it goes over the upper hole by at least 3 inches,and my over flow tank will be built outa dimond plate,and run the width of the rad. so that it all blends to together,i have tried many different angles with this setup and have found this to be the best so far,if i were to angle the rad up more then i would actually have less air flow across the rad. fins=higher temp...wich wouldn be good.
meangreen
meangreen
Posted: Tue Sep 23, 2008 08:29 AM
well,our 03' hyundai tiburon just met a ford f-150,and its a total loss,so we are guna buy it back from the insurence for $700 and i'm taking the front/back seats,a/c unit,power rack and pinion,and put it all into the baja,mabe even the guages if i can figure all the electrical out....so as soon as i get a chance it'l be baja time agin....work,family,so much to do so little time,and at this point i am gunna wing building a 1 pc front end cuz i caint find one reasonable i:e less than $1000 shipd so i have a "plan" so we will see how that goes.
meangreen
meangreen
Posted: Mon Sep 29, 2008 09:22 AM
ok,so i havnt gotn much done...i did get my rear cage all welded up to suport the rad....good news,once i mount the electric fans under the rad and have the engine installed i will have almost 3 inches of clearance between the fan and valve cover....oh yea,i am taking baja parts,and donations....i'll pay shipping ?....haha ? mybe not.....
meangreen
meangreen
Posted: Mon Oct 27, 2008 01:52 AM
ok so i aint got a lot dont on the baja,but after we wrecked the tiburon i gutted the seats,a/c,and steering column and am putting it all in the bug,here is a pic of the seats,now they aint mounted yet so they are a little low,and they need cleaned up real good....(flat bed wrecker+dirt road+windows down=DIRTY !!!!
meangreen
meangreen
Posted: Mon Nov 10, 2008 01:21 AM
ok,so i finished replacing my floor pan's...i finally gave up on the idea of building my own frame/pan....and by the way brazillian floor pans are really thin,and the people who build them need to try a different welding stratagy,becuz at the back of the pans there is the part that make up the rear "hump" under the seats,and i wanted to use the stok one cuz it felt alot stronger.....i was able to just pull that part off the pan...little resistance from the spot welds...anyway i wasnt able to get any pictures but i'll try tomaro.
90xjlimited4x4
90xjlimited4x4
Posted: Mon Nov 10, 2008 01:43 AM
haha
but in all seriousness i need pictures to keep me moving on my project!
5 Admin_AzBaja 6802 Baja Bugs on Wiki need...
1568 mufasavnvmc 999993 Re: what did you do to...
285 MusicManiac 241539 Re: Baja sightings
0 Northmountainauto 1535 Shop Baja
