Visitors: 123
Total: 123
11: Event Calendar
63: Event Calendar
118: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Alternator/charging dummy light
Sample
Sample
Post Post subject: Alternator/charging dummy light
Posted: Fri May 09, 2008 01:40 AM
How low must the alternator output be to trip the dummy light?
1966 Baja.
chrispy56
chrispy56
Post Post subject: Re: Alternator/charging dummy light
Posted: Fri May 09, 2008 07:17 AM
Im not too sure, but i think it is when you are using more amps or voltage that what is being created by your generator or alternator. or when it is below 12.5 volts ??????
Posted: Fri May 09, 2008 07:43 AM
Interesting question. Why do you ask?
I'm not absolutely positive, but I think the answer is 0 amps. I'm pretty sure the dummy light only comes on when you're not charging at all.
Sample
Sample
Posted: Fri May 09, 2008 06:32 PM
I had a dead battery on wednesday. I got a new one in, started the car and was only running at 12.5v even while revving. My light doesn't come on. However, the light does seem to work properly at other times. It comes on right when I turn the ignition on until the car is running. It comes on when I shut the car off for a second while the motor finishes turning. But it has never come on running at such a low voltage.
Posted: Fri May 09, 2008 09:39 PM
I would think you have an alternator problem- specifically voltage regulator setting. My low voltage light comes on when I start the car, and stays on until the first time I blip the throttle. What kind of voltage do you show with the engine running and headlights on (and off-road lights if you have any)? If it's less than 12v, you're going to be sucking your battery down again at night.
Sample
Sample
Posted: Tue May 13, 2008 01:49 AM
It turns out it is the brushes. My neighbor just happened to have an old alternator laying around. I pulled the brushes out of mine and compared to his. His were a bit longer. I put them in and now I get just over 13V while running.
Where can I order a new set of brushes?
Posted: Tue May 13, 2008 04:46 AM
I would think they'd be fairly easy to find at a good local auto parts store. If not, I'm sure you could fine them on the net.
No new posts VW Volkswagen & Baja Bug General Discussion Need Opinions On Light Bar
62 57baja 98358 Re: Need Opinions On L...
 Sun May 24, 2015 04:28 AM
69yellowbaja View latest post
what do you use
4 bdrdunes 2949 Baja bug rear led ligh...
 Thu Dec 18, 2014 02:55 AM
No new posts VW Volkswagen & Baja Bug General Discussion oil light
electrical
5 terribletommy 2179 oil light
 Thu May 22, 2014 08:56 PM
No new posts VW Volkswagen & Baja Bug General Discussion Brake light switch?? 3 sandbuggy 3087 Re: Brake light switch...
 Sun Nov 17, 2013 07:21 PM
No new posts VW Volkswagen & Baja Bug General Discussion best way to mount a light bar or roof rack? 7 woodin 13079 best way to mount a li...
 Mon Feb 07, 2011 02:31 AM
woodin View latest post
