AzBaja Site info
GPS
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- TIRES& RIMS
TIRES& RIMS
Users browsing this topic:
None
Author |
Message |
+15
Post subject: TIRES& RIMS
Posted: Fri Apr 25, 2008 07:16 AM
CAN I PUT 31,10/50 ON A 10" rim?whats a good size tire for the rear of a pretty stock swing? i know this has been asked before but i,m to lazy right now to look  thanks guys!!
_________________ ... HAMMER IT TO FIT,,PAINT IT TO MATCH !!! A people that values its privileges above its principles ,Will soon lose both!
+28
Post subject: Re: TIRES& RIMS
Posted: Fri Apr 25, 2008 07:18 AM
That tire is 10.5" wide, so it'll fit fine on a 10" wide rim.
+15
Posted: Fri Apr 25, 2008 07:20 AM
tread width is only 8 '' but its a 31 10/50
+28
Posted: Fri Apr 25, 2008 07:24 AM
If it's a 31x10.50, it's considered 10.5" wide, regardless of what the tread measures. It'll be fine.
Did you get some new tires/wheels? Thought I heard you say at Scott's that you'd sold yours and your new ones weren't in yet. Let's see some pics!!
+15
Posted: Fri Apr 25, 2008 07:33 AM
THEY ARE ON THE WAY,, 31.110/50 REARS,,,235/75R 15 FRONTS,,BOTH OTR,,,REAR DIA 30-5/8,,FRONT DIA,29.1/8,,FRONTS ARE 6,3/4 ''WIDE,, I,M DRIVING MYSELF CRAZY WITH THIS CRAP,,BEEN OUTSIDE MEASURING 1,000 TIMES,,HOPING TO GET THE LOOK AND TRACTION I,M LOOKING FOR,, TIRED OF IT JUST SITTING,,WHAT TO GO ON A RUN SO BAD IT HURTS!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! PICTS TO FOLLOW ALONG WITH A PAINT JOB TIRED OF THE GREY PRIME  R!!
Sample
+1
Posted: Fri Apr 25, 2008 08:21 AM
Not ideal as it will kind of balloon out near the lip, but it will work.
_________________ 1966 Baja.
+35
Posted: Fri Apr 25, 2008 03:38 PM
jamesr6168 wrote: |
CAN I PUT 31,10/50 ON A 10" rim? |
YES
_________________ Bugzyla Fabrication
+15
Posted: Fri Apr 25, 2008 03:41 PM
THANKS!
+3
+15
Posted: Sat Apr 26, 2008 03:02 AM
cool them there 10 " rims?
ditch68
+2
klwdesigns
Posted: Sat Apr 26, 2008 05:05 AM
my $.02, a 10" rim will make that tire look fat. If thats the look you want you're fine. I would get an 8" so when I have low air pressure there is far less chance of popping the bead. We can get away with wide tires and high air pressure more than the 4 x 4 guys because our rides are lighter, but 10" rims are more expensive, harder to come by and you will always need wide tires.
Ditch, I also would like a rounded tire, I'll be watching to see what you find. For the most part I just run used light truck tires. 235/75 R15. I think 31's are too much torque on a stock swingaxle transaxle. Wide tires are too heavy IMO also.
_________________ 3 (O\!/O) 's and 1 0!\_/!0 since 2001
Billy
Posted: Sat Apr 26, 2008 05:57 AM
My 2 cents:
I'm running 31s on the stock tranny and it can push them with BARELY any bog between gears. Sure, it guzzles gas,and I may point out that I have a 1641cc but still. Any bigger though.. i dunno... Plus then you're losing valuable clearance
_________________ (\\X/) (o\\ | /o) \r\n\'68 daily\r\n\'74 baja
+3
Billy
Posted: Sat Apr 26, 2008 06:41 AM
think mine are 8. Maybe ten. If forget, lol.
Picture Box
Great things to Buy
Other Sites
Parts - For your Car
