Latest: Milkmanbryan
Overall: 3583
Visitors: 131
Total: 131
02: Pictures
55: Event Calendar
76: Home
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Am I missing anything from this order? - updated
zx10r203
zx10r203
Post Post subject: Am I missing anything from this order? - updated
Posted: Tue Apr 15, 2008 07:36 AM
I will be placing a small order soon and just want to know if I am missing anything important. I know I am missing shocks, wheels tires, shifter and some other stuff but those will come later. Right now I am mainly working on the chassis since its off the pan. i did not put any brake stuff because I am not sure if I will be keep the stock drums or going to disc.
The list so far:
Urethane Shift Coupler
Transaxle Solid Mount Kit
Shift Rod Bushing
Shid Rod Bushing Clip
Triple Shock mount
Trailing Arm Box Kit
Urethane Trailing Arm Bushings
Front End Adjusters
IRS Adjustable Spring Plate
29m Torsion Bars, 26 9/16
Chrome IRS Torsion Caps
Accel Pedal
Accel Pedal Pad
Pedal Assembly
Accel Pedal Repair Kit
Belly Pan Gasket
Post Post subject: Re: Missing anything from this order?
Posted: Tue Apr 15, 2008 07:58 AM
who you going to place the order with? members get good deals at chirco's
zx10r203
zx10r203
Posted: Tue Apr 15, 2008 04:58 PM
Already planning on that!! Soon to be a full member here!!
Posted: Tue Apr 15, 2008 05:23 PM
Spring plate bushings, inner and outer.
Clutch and accelerator cables (since you will have the pedals out)
I would not do the adjustable spring plates personally. (not worth the $ IMO)
Other things if doing a large order:
New ball joints (German)
Brake rebuilds frt and rear, hardware etc.
Frt and rear wheel bearings and seals.
Tie rods
Steering coupler........
zx10r203
zx10r203
Posted: Tue Apr 15, 2008 06:56 PM
Tie rods
Why do you think the adjustable spring plate is not worth it?
Sample
Sample
Posted: Tue Apr 15, 2008 07:03 PM
Could throw in a turnkey 2180 for me?
1966 Baja.
zx10r203
zx10r203
Posted: Tue Apr 15, 2008 07:10 PM
Sure, how about 2? 1 in the car and another just as a spare?
Posted: Tue Apr 15, 2008 07:21 PM
zx10r203 wrote:
If you drive over rough surfaces (the main reason to build it) the adjuster gets beat up and then won't move. A friend tried them on a buggy that he raced with not so good results. I personally would rather set the torsions (a couple of times after they take their "set"), use the stock plates and use the money on other items. BUT the plates at Chirco's are cheap, so you can try them.
fatalifeaten
fatalifeaten
Posted: Tue Apr 15, 2008 07:34 PM
I'll take a couple as well! Smile
--Harlan Ellison
zx10r203
zx10r203
Post Post subject: Re: Am I missing anything from this order? - updated
Posted: Wed Apr 16, 2008 06:10 AM
The new list:
Shift Rod Bushing
Triple Shock mount
Front End Adjusters
Accel Pedal
Accel Pedal Pad
Pedal Assembly
Belly Pan Gasket
Clutch Cable
Throttle Cable
Complete Brake Line Kit
Front Wheel Bearings
Rear Wheel Bearings
Urethane Steering Coupler
Speedometer Cable
Front Arm Bushing kit
Urethane Trailing Arm Bushing Kit
this is it for now. What should I add??
Posted: Wed Apr 16, 2008 07:29 PM
You have trailing arm bushings twice, but no spring plate bushings.
By brake rebuild, I meant wheel cyl's, shoes, hardware, hoses. pos m/c sorry I wasn't clear.
Seals for wheel bearings,
What are you going to use for upper shock mts in the rear? Once you box in the arms and add the shock mounts, the oem upper mount is useless. There is a thread where Daryll showed a higher upper mount without doing a cage. (it is the project Ernest car)
One other thing you may consider to save some $$ is make your own lower shock mount w/tabs instead of the triple shock mount. (unless you want to run multiple cheaper shocks instead of 1 good one)
zx10r203
zx10r203
Posted: Wed Apr 16, 2008 07:57 PM
The outer (spring plate) bushing I can access that easy with the body on. I already have a new brake master cylinder I just picked up. Basically what I am trying to get is anything that might be a pain to get to with the body on. Like most of the front end stuff. Brakes I can just raise the car up and get those done.
I thought I had seen somewhere the triple shock mount welded under the arm. But for me it doesn't matter. I will be putting a cage in so I can mount the shock to it. Do you have the link for that thread on the upper mount??
Thanks for all the help!!
Posted: Wed Apr 16, 2008 10:11 PM
www.azbaja.com/Forums/...=2347.html
No new posts Projects and Builds Preston's Baja Project "Smokey" UPDATED - 10/26/09
96 Preston 58561 Re: Preston's Baja Pro...
 Tue Oct 27, 2009 11:57 PM
Grunt-0341 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Pro Seatz T Shirts...Placing order
19 bajawarrior 9095 Pro Seatz T Shirts...P...
 Thu Oct 01, 2009 04:36 AM
bajawarrior View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Wish me luck! UPDATED WITH PICS!!!!
20 kyle_pc_75 7973 Wish me luck! UPDATED ...
 Thu Apr 30, 2009 01:03 AM
Neander View latest post
No new posts Projects and Builds JumpinBruceB's Baja Build UPDATED with more 4/11/09
34 JumpinBruceB 15380 Re: JumpinBruceB's Baj...
 Sun Apr 19, 2009 06:56 PM
fast_1 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Some Updated Pics 6 trd2001 3302 Re: Some Updated Pics
 Sun Jul 13, 2008 03:42 PM
trd2001 View latest post
