Latest: BlackIrish05009
Overall: 3574
Visitors: 126
Total: 126
15: My Account
19: Event Calendar
44: Event Calendar
100: Pictures
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Shock for a b/j front??
zx10r203
zx10r203
Post Post subject: Shock for a b/j front??
Posted: Wed Apr 09, 2008 10:08 PM
I noticed there are not that many shocks for the ball joint front.
What are my opitions?
Post Post subject: Re: Shock for a b/j front??
Posted: Wed Apr 09, 2008 10:30 PM
Same boat. I got an idea though. Jeep cherokees have that SAME stupid upper shock mounts. Well this company something that makes it run normal shocks.
store.jksmfg.com/merch...Code=Shock
LMK If this is what you mean. I thought about this myself.
zx10r203
zx10r203
Posted: Wed Apr 09, 2008 10:38 PM
The only problem I am seeing with that is that you lose a couple of inches of shock. May limit the travel!! But still thats a great idea!!
zx10r203
zx10r203
Posted: Wed Apr 09, 2008 10:40 PM
Posted: Wed Apr 09, 2008 10:46 PM
also in the same boat
wtracing
wtracing
Posted: Wed Apr 09, 2008 10:58 PM
i run KYB's i used to run empi coil overs and that was a big mistake
Posted: Thu Apr 10, 2008 03:02 AM
Only loose about 3/4 to 1" which isnt that big of a deal!
zx10r203
zx10r203
Posted: Thu Apr 10, 2008 04:24 AM
Is that how big they are!! I thought it would be been a little bigger. I guess 1" isn't much when you get to install a better shock!!
nukeworker
nukeworker
Posted: Thu Apr 10, 2008 05:26 AM
Bilsteins. They got em for regular or cut and turned.
Posted: Thu Apr 10, 2008 05:41 AM
It says you loose 1.1" zx10.
It would be nice to run all the same shocks also, not stud shocks up front and different out back!
Posted: Thu Apr 10, 2008 05:48 AM
KYB,S GR-2
Posted: Thu Apr 10, 2008 07:08 AM
I used to use KYB GR-2's and they were great.
By looking at that picture, it looks like a Mickey Mouse solution. The stud looks too big for the top. I guess you'd drill the hole out bigger in your shock tower to make it work, but why shorten your travel? You want MORE travel than stock, not LESS.
.... Just my opinion...
ChazLawler
ChazLawler
Posted: Thu Apr 10, 2008 07:30 AM
Fox makes Class 11 reservoir shocks with 6.5" of travel. They are rather expensive, though, about $180 ea.
Posted: Thu Apr 10, 2008 07:41 AM
This is what route im going now
B/J
www.chircoestore.com/c...ts_id=1095
S/A
www.chircoestore.com/c...ts_id=1153
zx10r203
zx10r203
Posted: Thu Apr 10, 2008 05:54 PM
Those are nice,but for $180 ($360 front only) a pop I can get more stuff for the Baja.
Posted: Thu Apr 10, 2008 05:55 PM
These are the next best thing to the FOX's: www.chircoestore.com/c...ts_id=4093
Then the KYB bus shocks mentioned above.
Both of these are for cut and turned front ends.
I don't think having the same shock frt and rear is of any benefit. Most of the mid travel cars run 8-10 in frt and 12-16 in the rear. Nothing is interchangable frt and rear.
zx10r203
zx10r203
Posted: Thu Apr 10, 2008 05:57 PM
Would it be bad to run the Bilstein ^^^^ on a stock front (not cut and tuned)???
Basically what I am looking for is a good road ride since the car will be street legal and also good off road performance.
A friend of mine who has a street legal sand rail actually swaps shocks when he goes off roading (uses short king shocks). Then in the summer when he wants to drive the car on road he has to put in his road shocks (Tokico Illumina 5-way Adjustables).
Posted: Thu Apr 10, 2008 06:27 PM
They have a cheaper alternative, that shock is a entry level race quality.
Bilstein part # may be: B46-0620-H0 shows 5.49" travel as opposed to 6.65" travel with lighter valving.
zx10r203
zx10r203
Posted: Thu Apr 10, 2008 06:31 PM
Is that a chirco part number??
zx10r203
zx10r203
Posted: Thu Apr 10, 2008 06:32 PM
[quote="zx10r203"]
Is that a chirco part number?? And would the 1.16" of travel make that much of a difference?
Posted: Thu Apr 10, 2008 07:37 PM
Chirco's didn't show it on their site, but they may have it. Just tell Don the application. I found it on another site. Here is Bilstein's application guide:
www.bilstein.com/OffRoad.pdf
The difference in travel is from the application: cut and turn the beam and run a longer shock gets you more ground clearance, sits higher, and more travel since the shock is longer (more room before it bottoms out)
Is it worth it? Depends on what you want. I personally don't like the look of a stock height Baja, so to me it was worth the money I have thrown at mine.
zx10r203
zx10r203
Posted: Thu Apr 10, 2008 08:28 PM
I am not too sure if I can cut and turn the beam myself. Is there a how to laying around somewhere with pictures for reference??
ChazLawler
ChazLawler
Posted: Fri Apr 11, 2008 04:47 AM
You could swap out your Type 1 arms and spindles and use Thing parts, instead. You would gain 3" in height plus not have to worry about the ball joint popping out of the lower arm. I also understand that Radflo (radflo.com) makes Class 11 shocks. I couldn't find any specs on their site, but read a thread on racedezert that mentioned these shocks.
zx10r203
zx10r203
Posted: Fri Apr 11, 2008 05:11 PM
Anymore info on the swapping the for the THING arms and spindles? Which to use and where to find it?
Posted: Fri Apr 11, 2008 05:31 PM
Watch the classifieds, Samba, craigslist, junkyards etc. Some times hard to come by and not real cheap. If you want to keep a nice ride and get more lift, but no more travel; www.blindchickenracing.com makes lift spindles for ball joint front ends. Mark, aka crash comes around this site on occasion.
Posted: Fri Apr 11, 2008 08:18 PM
www.blindchickenracing..._parts.htm
Scroll down to last product. 225+ shipping. 3" lift spindles..
Thats what ill be doing. Maybe. I dont know how to lift a swing axle without stupid camber problems!
zx10r203
zx10r203
Posted: Fri Apr 11, 2008 09:33 PM
If I install the adjusters will that affect the ride quality??
Meaning by raising the front will make it stiffer and lowering make it softer?!?!?
twistedsmily
twistedsmily
Posted: Fri Apr 11, 2008 09:41 PM
from what i understand asdjusters dont change the spring rate just the angle of the arms (but i could be wrong)
zx10r203
zx10r203
Posted: Fri Apr 11, 2008 11:16 PM
Thats what I thought until I read this on Chirco : "These adjusters allow you to adjust the height of your car, as well as dialing in the ride. You can make it stiffer or softer with the turn of a wrench."
twistedsmily
twistedsmily
Posted: Sat Apr 12, 2008 02:57 AM
ah well then ok didnt know they changed the spring rate of the packs guess we learn a little everyday hehe
zx10r203
zx10r203
Posted: Sat Apr 12, 2008 04:17 PM
Can anyone else comment on this??
Does the adjusters change the spring rate??
Posted: Sat Apr 12, 2008 10:02 PM
The spring rate doesn't actually change, but the angle of the trailing arms being closer to verticle rides a little stiffer than closer to horizontal. I hope that makes sense.
No new posts VW Volkswagen & Baja Bug General Discussion Lifting a super beetle front end 1 72sbbaja 1852 Re: Lifting a super be...
 Wed Jul 02, 2014 04:42 PM
Front End question
12 ButchW 6332 Re: What's the best wa...
 Sun Oct 27, 2013 04:42 AM
No new posts Club AzBaja (Arizona Chapter) bj front disk brakes with raised spindles 2 vwboat 2952 Re: bj front disk brak...
 Thu Dec 13, 2012 03:03 PM
No new posts VW Volkswagen & Baja Bug General Discussion Shock Hoops
Wanting to build shock mounts without cutting the body
29 POCman 21779 Re: Shock Hoops
 Thu Nov 15, 2012 08:50 AM
POCman View latest post
15 onthefarm 9536 Number on the shock to...
 Sat Jul 28, 2012 05:03 AM
