Visitors: 101
Total: 101
02: Event Calendar
31: Pictures
82: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- How to for the front baja nose piece?
The following users give thanks for this topic Anonymous - Sat Apr 11, 2009 12:11 AM
zx10r203
zx10r203
Post Post subject: How to for the front baja nose piece?
Posted: Sat Mar 29, 2008 02:02 AM
I got a 7 piece kit from chirco and I am a little nervous about cutting the front to fit the nose piece. I did get the template from chirco but still I am a little nervous on cutting it.
Can anyone give me a how to on it??
Post Post subject: Re: How to for the front baja nose piece?
Posted: Sat Mar 29, 2008 02:49 AM
First thing is to put the hood on. Then start trimming a little at a time for the front apron piece until it fits the way you want. Then bolt the fenders on last. Every baja kit I have installed is a little different and there is always trial fitting involved.
Posted: Sat Mar 29, 2008 03:08 AM
Like Daryll says. bolt on the fenders 1st then take Black sharpi and mark the area in front of them that need to be cut. then Bolt the Hood on next and do the same thing. Last fit the Nose. Thats the way we have done it in the past. and it seemed to work. The back is the same way. Cutting less is better than more!!! after more is gone it harder to put more back Smile
zx10r203
zx10r203
Posted: Sat Mar 29, 2008 03:10 AM
What do you guys use to fix the front apron in place?? Rivets, bolts, screws???
zx10r203
zx10r203
Posted: Tue Apr 08, 2008 07:12 PM
twistedsmily
twistedsmily
Posted: Tue Apr 08, 2008 08:23 PM
super glue lol nah Im just kidin just didnt want your qeustion to go un aswered (it's the wrong answer but still an aswer)
Posted: Tue Apr 08, 2008 08:38 PM
Whatcha mean the front apron? Ill get some pics if that helps?
zx10r203
zx10r203
Posted: Tue Apr 08, 2008 08:48 PM
Ona 7 piece kit you get a lower front nose/apron piece.
Posted: Tue Apr 08, 2008 09:40 PM
Ohh.. I got 4 fenders, hood, and nose cone (no ducktal came with teh car) So I got a 7 piece. Umm ill go check and snap a pic..
oldfart
oldfart
Posted: Wed Apr 09, 2008 12:20 AM
NOT screws! Once your fitting is satisfactory drill thru the metal and glass part, nut bolt,flatwasher on the glass side. Experiment! Whatcha got in the garage? You can always redrill and just fill the glass holes.
Posted: Wed Apr 09, 2008 02:53 AM
Bolts, washers, nuts and if you want the glass to last, you can even use a rubber grommet on the glass and insert the bolt through the grommet and through the sheet metal. The rubber may help prevent the cracks.
5 Admin_AzBaja 6801 Baja Bugs on Wiki need...
1568 mufasavnvmc 999957 Re: what did you do to...
285 MusicManiac 241527 Re: Baja sightings
0 Northmountainauto 1534 Shop Baja
