Latest: jamlip
Overall: 3581
Visitors: 191
Total: 191
74: Event Calendar
77: Event Calendar
84: Event Calendar
92: Pictures
120: Event Calendar
144: Event Calendar
158: Baja Forums
179: Baja Forums
182: Baja Forums
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Is the coil over conversion kit worth it?
zx10r203
zx10r203
Post Post subject: Is the coil over conversion kit worth it?
Posted: Fri Mar 28, 2008 11:54 PM
Is the spring plate conversion kit for coil overs worth it??
Is it strong enough??
I will also be getting the IRS arm boxing kit and the triple shock mount to go with it.
Post Post subject: Re: Is the coil over conversion kit worth it?
Posted: Sat Mar 29, 2008 01:25 AM
I'm using these because the have the "bung" on the inside that fits inside the torsion housing. I can't tell from the pic you posted if those do but I believe the others would be stronger. They are from Pacific Customs.
www.pacificcustoms.com...01361.html
Sorry... can't get pic to work Embarassed .
zx10r203
zx10r203
Posted: Sat Mar 29, 2008 01:55 AM
They look almost the same.
This is the one I posted:
http://www.mooreparts.com/store/product/4625/XAC501350-US/
images.nitrosell.com/p...350-US.JPG
What about this kit?
http://www.pacificcustoms.com/AC501361K.html
What should I go with and what kind of shocks would I need for something like this?
Posted: Sat Mar 29, 2008 02:02 AM
Posted: Sat Mar 29, 2008 02:06 AM
It depends on what arms you are going to use what kind of travel,terrain, etc. you will be in. Tell us a little more.
zx10r203
zx10r203
Posted: Sat Mar 29, 2008 02:18 AM
My bad!! FOr now I will just be boxing the stock IRS arms. Terrain will probably mostly sand dunes, but the car will be street legal. Travel wise I would like to get as much travel as possible without spending an arm and a leg. The car is still being built and I am just researching what my options are. I had a sand rail a while ago and the swing plate limited and acutally broke the lower piece of the braket on the torsion housing everytime it hit.
Posted: Sat Mar 29, 2008 04:28 AM
If you are staying with the stock arms the stay with the stock gear get some better shocks (not empi coilovers either) , save up your bucks for those and some longer trailing arms and coil overs.
Besides if you go with the above setup you will have to get coilovers as those will eliminate your torsions.
zx10r203
zx10r203
Posted: Sat Mar 29, 2008 04:48 AM
What about the adjustable spring plates?? Can those give you a little more lift??
Posted: Sat Mar 29, 2008 08:10 AM
That is probably the easiest, also you can do the adjustable rear torsion for the rear also but that requires cutting the rear torsion housing.
Posted: Sun Mar 30, 2008 01:12 AM
Yea zx, Leatherneck is right in that the adjustable plates are easiest. I was a little chicken$*%@ in cutting the rear torsion housing for the single adjustable option so I went with the adjustable plates. They are however not real easy to change unless you get the torsion plate tool. Scary stuff here since those bad boys are under some serious load even sitting on the stops.
trd2001
trd2001
Posted: Thu Apr 17, 2008 05:53 PM
My buddy had those on his Baja, and then ended up bending them after a while. He removed them, and did what wer did on mine.
On my baja, i have 2.5 Fox Coilovers in the rear, with a SAW spring plates. I still have the Stock Torsion Bars, with no preload on them. If i remove the Coilovers, it will rest about 1/2 from the stops. I been running it this way for 3 years now, with no problem.
ditch68
ditch68
Posted: Fri Apr 18, 2008 04:22 AM
You are talking about 2 completely different systems seperated by vast amounts of cash.
The first set, which eliminates the torsion bars, requires coilovers, and would be a complete waste if you elected to stay close to the stock travel setup. Going beyond that would obviously require CVs which could handle the angles, etc. If you are doing this, then just go for it...3x3 trailing arms (or better), long travel coilovers, and so on.
The adjustable spring plates would give you tunability, but travel would still be restricted by the arm setup, torsion bars would be strained and the ride would change as you cranked them, and ultimately, you would still be where you would be with a homegrown torsion bar index without the pain in the ass work.
Now, some of you run torsions with coilovers? How do you select coilovers with the torsion bar factor figured into the coilover rate?
I gess I view coilover and torsion as 2 seperate approaches to the same problem, coilover being the more cost and travel intensive..
Jeff
Beer is NOT AN OPTION....
(meaning not optional)
1971 Type 3 Squareback FI/AT
Posted: Fri Apr 18, 2008 04:37 AM
Ill take some SA rear car, pics, and can you help me find out, i got coil overs on it, I need to find out how to adjsut torsion!
tigerextra
tigerextra
Posted: Fri Apr 18, 2008 06:34 AM
Jeff
...ditto Rolling Eyes Very Happy
you hit it on the spot.
I enjoy every second of it!!
And a side note added,
all 6 of us agree!!
tigerextra
tigerextra
Posted: Fri Apr 18, 2008 06:35 AM
i was going to add something to the write up... but you pretty much got it all, just thought I might stress that Smile
all 6 of us agree!!
No new posts VW Volkswagen & Baja Bug General Discussion What is my Baja really worth? 1 Treeposter 1756 What is my Baja really...
 Sat Jun 17, 2017 04:06 PM
No new posts Projects and Builds my 74 Ghia conversion 3 _-Mad-Max-_ 2841 my 74 Ghia conversion
 Sat Jul 20, 2013 12:08 AM
_-Mad-Max-_ View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Does any one have any coil over springs for 2.5 shocks?
16 Ejbbal21 8565 Does any one have any ...
 Sat Oct 06, 2012 10:05 PM
Ejbbal21 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Is this baja worth the buy?
Help me decide if this baja's worth what there asking?
7 kylechaffee 5358 Re: Is this baja worth...
 Sat Sep 10, 2011 01:15 AM
kylechaffee View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Link Pin Conversion 8 Bryman042 6508 Re: Link Pin Conversio...
 Thu Jun 23, 2011 12:41 AM
Bryman042 View latest post
