Visitors: 127
Total: 127
71: Event Calendar
75: Event Calendar
86: Event Calendar
111: Event Calendar
117: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- starting engine
starting engine
cperry2704
cperry2704
Post Post subject: starting engine
Posted: Mon Dec 31, 2007 11:19 PM
im trying to get my engine started and happened to brush up against the coil, and it was almost too hot to touch! is this normal? or should the coil not be that hot?
cperry2704
cperry2704
Post Post subject: Re: starting engine
Posted: Mon Dec 31, 2007 11:36 PM
also does the distributor wire go on the positive or negative post on the coil?
Posted: Tue Jan 01, 2008 12:35 AM
Dizzy (points & condenser) to Negative on coil.
cperry2704
cperry2704
Posted: Tue Jan 01, 2008 01:03 AM
now should he choke be getting hot to the touch?, there is something within the automatic choke, that is keeping the engine from idling, that is keeping the butterfly from closing enough
Posted: Tue Jan 01, 2008 01:08 AM
Where is the wire going to the choke coming from?
cperry2704
cperry2704
Posted: Tue Jan 01, 2008 01:30 AM
the wire goes from the coil, to the sylonoid on the carb, then splits to the choke
Posted: Tue Jan 01, 2008 01:34 AM
From Positive side of coil to choke, yes?
cperry2704
cperry2704
Posted: Tue Jan 01, 2008 01:45 AM
yes...think we found the problem, the guy that built our engine, put a 6volt choke on instead of 12volt, so that could be why its getting so hot, and not functioning properly? just wondering if the coil is a 6volt also!
Posted: Tue Jan 01, 2008 01:56 AM
Good catch, why would he do that? Get a chance ask him. D'OHT
Posted: Tue Jan 01, 2008 04:07 AM
make sure u have coil with a ballest resitor. a coil is just a coil of wire so when the point are closed you creat a short/ burned points etc. Coils come in 2 basic types ballest and non ballest if you have one with a bilt in ballest your good to go, if your coil does not have a built in ballest you need to get one or you will start to burn things up, Ballest is a white block.
Ballast pictures
with out it things will get real hot like your coil.
Good info about coils click and read
Posted: Fri Feb 29, 2008 08:31 AM
bump
No new posts VW Volkswagen & Baja Bug General Discussion Engine kit 0 andrewbaja 1323 Engine kit
 Thu Mar 29, 2018 04:13 AM
andrewbaja View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Engine Work 5 ghs215 2093 Re: Engine Work
 Mon Jan 08, 2018 01:59 AM
No new posts VW Volkswagen & Baja Bug General Discussion VW engine stand 2 ghs215 2396 Re: VW engine stand
 Thu Jun 01, 2017 10:28 PM
Trevabooooy View latest post
No new posts VW Volkswagen & Baja Bug General Discussion i need some subaru engine assistance with my baja 1 Prayinmantis 2450 i need some subaru eng...
 Mon May 23, 2016 03:06 AM
5 bajabuggy69 4978 Rebuild and engine swa...
 Fri Sep 05, 2014 06:23 AM
spheromike View latest post
