Visitors: 117
Total: 117
27: Event Calendar
28: My Account
31: Home
65: Event Calendar
84: Pictures
Baja Forums -:- Off-Road & VW Based Clubs (4x4, ATV, Jeep, Motorcycle) -:- Events and Get Togethers World Wide -:- DO YOU NEED A HAND WITH YOUR BAJA?
The following users give thanks for this topic Anonymous - Wed Mar 18, 2009 12:00 AM
papus67
papus67
Post Post subject: Re: DO YOU NEED A HAND WITH YOUR BAJA?
Posted: Tue Apr 30, 2013 06:22 AM
perrib wrote:
Remove the pulley and see if it appears to have threads where the pulley enters the case. These are there to force the oil back in, also the oil slinger needs to be there. If the area behind the pulley is smooth it is for a sand seal. Either install a seal or a stock pulley. If it a stock engine make sure the breather is open. Larger engines need more breathing. If oil is blowing out the ring seal is bad.
Thanks for the tip, will be my weekend project since I went thru everything else
AndrewK
AndrewK
Post Post subject: DO YOU NEED A HAND WITH YOUR BAJA?
Posted: Tue Oct 07, 2014 06:23 AM
Hey what's up guys, I would love some electrical help with my 1969 baja. I kind of have all the electrical torn out and a loom ready to go in with everything where it "should" be... but some of my beetle is 12v and some is 6v. With a electric fuel pump and some lights up top. I just look at it and realize I have no idea what I'm doing.
Posted: Thu Oct 16, 2014 04:33 PM
69 should all be 12v. What is 6v in the cr?
klwdesigns
klwdesigns
Posted: Thu Nov 17, 2016 03:35 AM
I need to sell my '64 baja bug. It has been with me for 15 years, but I need some cash. I got it to start, but because it sat for so many years it is running rough. I drained the laquer from the gas tank, replaced the flexible fuel line (most of it) put in new points and replaced some cracked wiring.
The exhaust had a crack in one of the tubes, so water got in and made rust inside, it actually blows rust colored smoke out of the exhaust.
It does have a vacuum leak I believe, an inlet on the carb pedestal. 34 pict carb on it. If I recall, there was a rubber boot that went over that, but since BAP parts on Broadway closed down, I'm not sure where to get VW parts on the east side.
I hate to tow this in to Dougs Bugs and Bunnies and pay shop fees, but I think it'll sell easier if it is running right. Plus I might want to drive it one last time before letting it go.
I'll probably bleed the brakes this weekend.
Anyone out in the east valley good with tuning carbs?
moniker
moniker
Posted: Fri Dec 09, 2016 06:51 PM
Anybody here familiar with the ecotec swap? 16 year old kid here who has a little bit of a clue of what he's doing. I have a 68 Baja with a SP 1300 that I feel is on its way out. If someone could tell/inform me what's needed and maybe help, I'm willing to pay. I live in the east valley, and I'm located literally 5 minutes away from Bulldog Canyon which I see is quite popular here.
tcataz32
tcataz32
Posted: Wed Jan 18, 2017 05:46 PM
So I am new to the VW Baja world. I actually have a 69 Baja Bug and a 70ish VW sand rail. I live in the surprise area. The sand rail, run decent but at full throttle it kind of dies out. My first thought is the fuel pump is going bad and a full throttle it does not pump enough. Any other thoughts or a simple way to check that?
Also if anyone would want to come over and tell me what I actually have. I got these two because someone owed me money and taking them was the only way I figured I would get anything out of it.
vwboat
vwboat
Posted: Thu Jan 19, 2017 06:03 PM
Welcome to the site. Lots of good info on here as well as help.
VWboat(JOHN)
tcataz32
tcataz32
Posted: Tue Jan 24, 2017 02:35 PM
So the baja bug I got the brakes suck on it. So I found a kit to convert the front to disc. How hard is it to convert the front to disk and rebuild everything on the drums in the back?
TINMAN
TINMAN
Posted: Wed Jan 25, 2017 02:06 PM
disc brake conversion is simpler than rebuilding drums. get lifted spindles while your at it.
TRUMP 2020
Adub
Adub
Posted: Wed Jan 25, 2017 03:03 PM
Where could one find a rear disc conversion kit?
tcataz32
tcataz32
Posted: Wed Jan 25, 2017 03:15 PM
disc brake
This is where I was looking
TINMAN
TINMAN
Posted: Thu Jan 26, 2017 12:12 AM
I have ordered from J bugs many times they ship quick and I have never had an issue CIP 1 and Pacific customs are also great.
TRUMP 2020
5 Admin_AzBaja 7119 Baja Bugs on Wiki need...
1568 mufasavnvmc 1012460 Re: what did you do to...
285 MusicManiac 244431 Re: Baja sightings
0 Northmountainauto 1696 Shop Baja
