Visitors: 111
Total: 111
23: Event Calendar
47: Event Calendar
84: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- just bought a beetle with no key
speedtrash
speedtrash
Post Post subject: just bought a beetle with no key
Posted: Sat Jun 24, 2006 06:19 AM
my problem is i can't figure out how to get the ignition cylinder out. i need help!
Post Post subject: Re: just bought a beetle with no key
Posted: Sat Jun 24, 2006 06:42 AM
what yr is the bug? is the ignition in the dash or on the column?
speedtrash
speedtrash
Posted: Sat Jun 24, 2006 06:51 AM
it's a 74 and the ignition is on the column
Posted: Sat Jun 24, 2006 07:07 AM
74 is a pain. You have to disassemble most of the column staring with the plastic top & bottom covers. You might as well pull the steering wheel off first to make the job easier. There is a pot metal casting under all that with the ignition key and tumbler in it. Its been a few years since I have done one, but I believe there is a set screw that holds it in.
speedtrash
speedtrash
Posted: Sat Jun 24, 2006 07:27 AM
thanks for the info, i'll check it out when i get a day off of work.
speedtrash
69bapbaja
69bapbaja
Posted: Sat Jun 24, 2006 08:44 AM
big d forget to mention that first the steering wheel, then the turn signal and wiper switch, then pull those out and you will see the steering bearing. to the right of that you will see two screws that holds the ignition switch housing. pull that off and you will need to make sure that the steering will doesn't lock up. pull the unit out and you will see the little set screw at the top. pull that out and set it some place that you won't lose it. Then remove the key part of the switch match it up with the new one. then replace, and re assemble the colum. trust me it won't be the last time that you have to replace it
OWNER OF
Two Kats Tats
5030 W. Peoria
Glendale, AZ
85302
(623) 934- 9197
Posted: Sat Jun 24, 2006 03:04 PM
Yeah what he said ^^^^
speedtrash
speedtrash
Posted: Sun Jun 25, 2006 01:47 AM
you say i need to make sure the steering doesn't lock up, how do i do this? keep in mind right now my steering is already locked up.
Wiggins
Wiggins
Posted: Sun Jun 25, 2006 02:39 AM
OK, scratch the "make sure the steering is'nt lock up yet." Rolling Eyes
General Manager
www.chirco.com
www.chircoestore.com
69bapbaja
69bapbaja
Posted: Sun Jun 25, 2006 06:29 AM
jam a screw driver into it and turn it un locking the the steering wheel . because the pin that locks the wheel will not alow you to pull the houseing out. I. e. alowing you to get to the small screw to let lose the key and tumbler.
while you are in there take a look at the electrical portion of the switch. once you get the key part into place turn the key and if the switch is worn you will see the plastics separating . now would be an awsome time to do it.also to get a closer look at things . the electrical portion is held in place like the key part. with a little bitty screw.
OWNER OF
Two Kats Tats
5030 W. Peoria
Glendale, AZ
85302
(623) 934- 9197
bajahank
bajahank
Posted: Sun Jun 25, 2006 06:29 PM
Or you could buy the steering column that I have with the key and just swap them out. All I want it the $100 I paid for it and shipping.
speedtrash
speedtrash
Posted: Sun Jun 25, 2006 06:39 PM
thanks for the offer hank i'll keep it in mind but for now i'm gonna tinker with this one. i'm broke right now anyways, plus my daily driver just broke down.
bajahank
bajahank
Posted: Sun Jun 25, 2006 08:41 PM
No problem, I brought it for my baja and then found out that it not the right year. It's out of a 74 I think but the guy said it would work in a 75. So, if anyone else is in need of a steering column with key let me know.
speedtrash
speedtrash
Posted: Fri Jun 30, 2006 06:16 AM
well i went at it with a screwdriver and all i did was mame it. i worked it for a while on about three different occasions but it won't turn. can anyone give me detailed instructions on how to get it to turn. am i supposed to just use brute strength(i hope not because i tried that).
69bapbaja
69bapbaja
Posted: Fri Jun 30, 2006 07:46 AM
there is a snap ring in the center of the house that holds the colum bearing. remove that and loosen the nut on the bottom of the housing and the two bolts holding the colum up to the body. Be carefull not to break the bearing and it's housing.
OWNER OF
Two Kats Tats
5030 W. Peoria
Glendale, AZ
85302
(623) 934- 9197
1 suburbangorilla 3682 CONVERTING '71 STOCK B...
 Wed Apr 01, 2015 11:51 AM
No new posts VW Volkswagen & Baja Bug General Discussion big beetle 3 bugzapper 2600 big beetle
 Wed Dec 17, 2014 05:07 AM
No new posts VW Volkswagen & Baja Bug General Discussion Lifting a super beetle front end 1 72sbbaja 2223 Re: Lifting a super be...
 Wed Jul 02, 2014 04:42 PM
No new posts Projects and Builds bought a turd…. better get out the polish!
been a while...
7 acousticrawk 6102 bought a turd…. bett...
 Sun Jun 22, 2014 11:44 AM
No new posts VW Volkswagen & Baja Bug General Discussion super beetle baja bug 4 vtbaja 5021 Re: super beetle baja ...
 Wed Aug 14, 2013 04:48 AM
