Latest: jor_dang420
Overall: 3597
Visitors: 72
Total: 72
03: Event Calendar
19: Pictures
24: Event Calendar
34: Pictures
38: Home
44: Event Calendar
46: Event Calendar
50: Event Calendar
60: My Account
62: Event Calendar
67: Pictures
68: Event Calendar
71: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Swapped my gen out for an alternator
Jimmyjack
Jimmyjack
Post Post subject: Swapped my gen out for an alternator
Posted: Wed Jan 23, 2008 02:22 AM
Wow!!!! What a difference! I decided to just scrap the generator. I took a close look at the stator where the brushes rub. It was missing chunks of copper. Then I got in hit in the eye with something from the inside of the generator that flew out. That was it. I ripped it out of the rail in record time.
The alt kit was $160 from Bugs and Buggies in Tucson. They were pretty cool and walked me through he install. Not too difficult but i'd never done it before. It took all of an hour to complete the job and it is such a huuuuuge difference. It puts out a solid 14.5 volts and 51 amps.
I got a little froggy and ripped the gen apart and what a mess. I think every bit of insulation was missing from the wire, It had a massive crack on the inside of the case. And I wonder why it didn't work.
Post Post subject: Re: Swapped my gen out for an alternator
Posted: Wed Jan 23, 2008 02:31 AM
You know what they say...
...once you go alternator, you never go back. Wink
Jimmyjack
Jimmyjack
Posted: Wed Jan 23, 2008 04:13 AM
Amen to THAT!!!! Now if I can just undo the cut and turn I butchered together on my front end I'll be happy.
Posted: Wed Jan 23, 2008 08:35 PM
Did you need to got to the altenator style fuel pump (assuming your using the mechanical one) and shorter pump rod?
From what I understand, that's nessesary when switching.
Jimmyjack
Jimmyjack
Posted: Thu Jan 24, 2008 02:15 AM
ummmmmmmmm.... Shocked No, everything hooked up and fit OK. The only prob I had was the intake manifold. I had to remove the driver side ports to get the carb on. I need to get a small riser for the carb or grind away a small piece of the alternator. The carb touches the alternator and I didn't hook up the electric choke before I put it all together so now I have no choke. Other than that small detail it was an easy swap.....
Never heard anything about the fuel pump.
28 seanoflinn1 11814 Re: Can Somone take a ...
 Mon Jun 14, 2010 11:07 PM
No new posts VW Volkswagen & Baja Bug General Discussion Wanted VW alternator core 2 bajawarrior 1769 Wanted VW alternator c...
 Sat Jun 27, 2009 10:21 PM
catchbats View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Alternator/charging dummy light 6 Sample 2191 Re: Alternator/chargin...
 Tue May 13, 2008 04:46 AM
57baja View latest post
No new posts VW Volkswagen & Baja Bug General Discussion alternator 5 tigerextra 2590 Re: alternator
 Wed Dec 05, 2007 11:30 PM
tigerextra View latest post
