Latest: Milkmanbryan
Overall: 3583
Visitors: 192
Total: 192
15: Event Calendar
16: Pictures
18: Pictures
20: Pictures
29: Event Calendar
52: Event Calendar
63: Pictures
81: Pictures
89: Pictures
97: Pictures
99: Pictures
110: Pictures
146: Contact Admin
148: Pictures
150: Baja Forums
151: Event Calendar
158: Pictures
160: Pictures
164: Baja Forums
165: Event Calendar
166: Baja Forums
171: Baja Forums
172: Pictures
176: Baja Forums
177: Pictures
178: Baja Forums
179: Pictures
181: Baja Forums
182: Baja Forums
183: Pictures
186: Pictures
190: AMAZON.com
191: Baja Forums
192: Baja Forums
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Pedals- Bullet proofing
The following users give thanks for this topic Anonymous - Wed Apr 08, 2009 10:56 PM
Post Post subject: Pedals- Bullet proofing
Posted: Sun Mar 16, 2008 10:43 PM
Just read an article in the April edition of Hot VW's that talks about bullet proofing your pedals. This made me inspect my assembly a little closer than I had originally and a good thing to. My clutch cross shaft hook is worn quite a bit. The rest appears fine. Stripped it all down to clean, inspect and paint.
The article talks about that as well as beefing up the clutch pedal by adding some metal to the rear/side of the pedal. Neat idea and I spent an hour or so bending and tweaking a piece of 1 1/2 inch metal to fit and weld once the cleaning is done.
So here are my questions: Question Question Question Question Question Question
1- have any of you guys done this mod to the pedal?
2- Would you fill in the worn clutch hook with weld and then clean it up or would you just by another?
Post Post subject: Re: Pedals- Bullet proofing
Posted: Sun Mar 16, 2008 11:01 PM
Funny you ask. I just spent Friday night welding up a clutch hook, When it was done it was a lot stronger. I have also needed to weld up my clutch pedal arm because it broke. I didn't put a new plate on it, but it seems like a good idea.
Posted: Mon Mar 17, 2008 12:16 AM
I usually weld the hooks up and grind them down too. The weld is actually harder than the original metal and will last longer.
Posted: Mon Mar 17, 2008 01:43 AM
Very Happy
Ok guys. Weld it up I will.
Thanks.
fatalifeaten
fatalifeaten
Posted: Mon Mar 17, 2008 06:25 AM
No lie, the hook looked 100x stronger than the rest of the pedal cluster Smile
--Harlan Ellison
Posted: Mon Mar 17, 2008 09:53 AM
Hmmm.
Looks like I got to buy the issue. I've never heard of that.
Posted: Mon Mar 17, 2008 10:11 AM
I broke a pedel on my baja. strange feeling when it drops to the floor. good thing I can drive with out useing the clutch. Rolled into BAP picked up a new clutch pedel and put it on in the parking lot.
Posted: Mon Mar 17, 2008 03:45 PM
No kidding fatalifeaten, that sucker looked "beefy" but they say the better one is dificult to find so I started looking for the next best thing, Bupack. Couldn't find any site that claimed they carried those except Bupacks, but they don't show prices online.
I may just take the same material I used to beef up the pedal and add it to the hook, grind and make pretty. Although I think it's soft metal. Guess I'll have to harden it with some fire.
You guys think one of those plumber type torches using MAPP gas would be enough to harden?
fatalifeaten
fatalifeaten
Posted: Mon Mar 17, 2008 11:16 PM
why not just cut a new one out of 18" or 1/4" plate?
--Harlan Ellison
Billy
Billy
Posted: Tue Mar 18, 2008 10:21 PM
knowing how to drive without clutch is good. I never have had to but I taught myself and can do it ok enough to limp out of a bad situation.
Posted: Wed Mar 19, 2008 09:46 AM
I had to drive for a week without a clutch once when I was broke and broken at the same time. It was a pain in the ass, because I had to drop off the kids at a daycare center up in the hills with a lot of red lights.
It can be done.
It's just a little bit of a challenge.
Sorta like when you break a throttle cable and have to tie your shoelaces together to rig one up going out your side window.
Done that too.
Add a cup of coffee in one hand, shifting, braking, turn signals, and clutching, and you have a new Olympic event! Don't bother answering the cell phone if it rings. It can't be done.
Posted: Wed Mar 19, 2008 12:39 PM
O'ya forgot about the broken throttle cable. at least I have hole in the fire wall were the cage runs than I run my cable to a set of vice grips.
Stopping sucks then the starting it up again looks real funnny.
Athlon64
Athlon64
Posted: Tue Jan 27, 2009 01:35 PM
Getting the rusty old pedal assembley apart can be a challange in it self. I had to heat the rusty old set i got up to allmost red hot to drive out that pin. to replace the brake return spring. Man that little pin would not budge! Untill I used the heat wrench, then out it came. Cleaned it all up, replaced the spring and painted it up with rustolem paint. The biggest problem I had was the pedal mount from EMPI. I will never buy anouther one of those CHEAP things again. I had to weld and renforce it 2 times with steel plates to keep it from bending and the stop at the bottom wasen't even close to being right. I spent 4 hours on makeing that POS work. I sent them a nasty gram on that one.
30 year triple Master EVT, ASE, heavy truck, automotive certified emergency vehicle mechanic
abcprint
abcprint
Posted: Tue Jan 27, 2009 02:37 PM
and if you have three daughters who think the clutch is to hard to push you can add a 1/2 inch to the hook for more leverage....
66 Baja
No new posts VW Volkswagen & Baja Bug General Discussion Water proofing distributor
Heat shrink?
3 ButchW 2401 Re: Water proofing dis...
 Wed Oct 02, 2013 04:00 PM
ButchW View latest post
