Visitors: 135
Total: 135
04: My Account
16: Event Calendar
72: Event Calendar
87: Event Calendar
107: Home
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- What would I need for 5x5 trailing arms?
zx10r203
zx10r203
Post Post subject: What would I need for 5x5 trailing arms?
Posted: Thu Jan 10, 2008 11:08 PM
I am building a 73 and as of right now with the crappy weather I have not been able to work on it much. So with all the down time I have been thinking of putting on some 5x5 trailing arms on it. Can anyone tell me the exact parts that I would need to install the 5x5s!!
Or would the 5x5's be overkill? The car will be street driven also.
Any suggestions?
Thanks in advance!!
Post Post subject: Re: What would I need for 5x5 trailing arms?
Posted: Thu Jan 10, 2008 11:34 PM
I know for sure that you need a wider torsion housing and I think you have to move the trans and engine back a couple of inches.
Posted: Fri Jan 11, 2008 04:26 AM
BCR 5x5 trailing arms hung on a stock torsion housing, 23 mm 944 Porsche long torsion bars, for now.
engine 2.3 Ford and Rancho Pro 3 rib tranny in stock location, late model Vanagon axles, type 2 cv's, stub axles with 944 Porsche disc brakes. .
Posted: Fri Jan 11, 2008 04:28 AM
Oh yes 1 more thing, the wheels are steel Porshe with an inboard off set.
Posted: Fri Jan 11, 2008 04:45 AM
Ok, I'm confused... I bought a set of 5x5's for my car and they didn't fit. When I bolted them on at the pivot they were 2" too wide. I would need a spacer between the arm and springplate Confused .
Posted: Sun Jan 13, 2008 06:44 AM
Any ideas???
Posted: Sun Jan 13, 2008 12:36 PM
I know I had a time getting the urathane bushings in. Once the arms were pinned in the piviot box everything fell right into place. Are your arms from BCR also? Do you have pictures of the setup with those arms?
on hold baja build
"when I nod my head, HIT IT"
Posted: Sun Jan 13, 2008 04:24 PM
I don't know who made the arms. When I couldn't get them to fit, I sold them. My only solutions were a wider torsion or move the pivot pionts to inside of the frame horns Shocked . Oh well.....
T_Town_Baja
T_Town_Baja
Posted: Mon Jan 14, 2008 03:57 PM
Is your car a natural IRS? or was it converted? From the sounds it may have been converted and whomever welded the Pivot brackets, didnt put them in the right location?
They should be into the framehorns about an inch or so, are yours not?
Blaine
Posted: Mon Jan 14, 2008 11:45 PM
My guess is they were made for a wider torsion housing. There are people who run extension boxes on their torsion housing, or use a custom housing to fit the "big boy" arms. Us peasants just stick with the 3x3's. Laughing
Posted: Tue Jan 15, 2008 12:35 AM
My car is originally an irs... the arms must have been made for a wider torsion housing... Oh well... I ended up going with what the rest of the peasants use...3x3's Wink .
Sample
Sample
Posted: Tue Jan 15, 2008 12:39 AM
Man I wish I made atleast peasant wage. What do you call those that cannot afford anything but swing axle? Wink Very Happy
1966 Baja.
Crash
Crash
Posted: Tue Jan 15, 2008 04:38 AM
Indentured Servants
Mark Johnson
Blind Chicken Racing
www.blindchickenracing.com
Posted: Tue Jan 15, 2008 05:43 AM
Sad ME!!
No new posts VW Volkswagen & Baja Bug General Discussion wanting feedback on 3 x 3 rear arms 10 ROCKSLAYER 11124 wanting feedback on 3 ...
 Thu Jan 27, 2011 06:01 AM
jon6.0 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion 3x3 arms 8 texbroker 8123 Re: 3x3 arms
 Mon Nov 30, 2009 12:41 PM
No new posts Projects and Builds Bugzyla Trailing Arms 2 BugZyla.com 4223 Re: Bugzyla Trailing A...
 Tue Oct 06, 2009 02:13 PM
No new posts VW Volkswagen & Baja Bug General Discussion JWH Racing trailing arm beta test. 5 perrib 4481 JWH Racing trailing ar...
 Fri Jul 31, 2009 06:19 PM
DONT View latest post
No new posts VW Volkswagen & Baja Bug General Discussion extended axles trailing and swing arms!!! help 10 nath_baja44 8538 extended axles trailin...
 Sat Jul 11, 2009 04:54 AM
nath_baja44 View latest post
