Latest: bawward
Overall: 3614
Visitors: 149
Total: 149
03: Event Calendar
05: Event Calendar
18: Event Calendar
25: My Account
34: Pictures
59: Pictures
66: Home
79: Garage
84: Contact Admin
98: Pictures
99: Home
117: Event Calendar
131: Event Calendar
141: Pictures
147: Home
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Light Bar Wireing?
Light Bar Wireing?
Post Post subject: Light Bar Wireing?
Posted: Sun Jun 25, 2006 11:52 PM
I just picked up the light bar(thanks Say 10) and I was wondering how did those of you who run a light bar wired the lights? Did you you use relays? How many? Seperate switches for sets of lights? Just looking for ideas for mine.
azhunter
azhunter
Post Post subject: Re: Light Bar Wireing?
Posted: Mon Jun 26, 2006 12:52 AM
I'd advise you to run a relay to burden the load. most lights pull to much amperage for a switch. If you run four lights. I'd advise to run pairs, two and two. Just like dim,bright. You don't always need four, but sometimes two isn't enough
Posted: Mon Jun 26, 2006 03:09 AM
if you buy the lights new, they come with their own switches. you need inline fuses (30A/ pair of 100w lights). switch the inner 2 together, the outer 2 together. you can penetrate the top corner of the roof and run the wire harness down the windshield corner out of siht. i ran mine in split loom wire manager down the rain rail on the drivers side into the antenna hole. run 2 wires per pair of lights to the bar. run a red for hot and a black for ground. run the ground to the inside of the car. do not ground to the light bar.
any more questions?
Staff Officers
Posted: Mon Jun 26, 2006 05:50 AM
I run my wire down the drip rail in the back of the car into one of the heater holes. I have the reals wired to a terminal block next to the batery. I have the wres that run the relays. run up the heater cahnel and into the dash.
Simpl and you can have a nice big fat wire run to the relays from the battery. Last do not dril hole into the lid of your Baja. It will leak and drip and once it is done you can not fix it.
Posted: Mon Jun 26, 2006 07:18 AM
I bought the 30AMP millitary style (flip top lid) and I wired them in pairs. The relays weren't marked and they made me mad so I smashed them. (Stupid Relays!!! Mongo no like!!!) Evil or Very Mad
I used a fuse and it works fine!!
Posted: Mon Jun 26, 2006 07:25 AM
you must have an inline 30a fuse per pair of 100w (ea) lights. use the newer style flat fuse holder with flip cap. it keeps dirt ans moisture out.
Posted: Mon Jun 26, 2006 04:16 PM
Thanks for the info!!
Posted: Mon Jun 26, 2006 09:37 PM
want pics?
Posted: Mon Jun 26, 2006 11:20 PM
Yes!! and is anyone useing some type of quick disconnect? Such as a trailer hitch style so that you can remove the bar if you want?
Say10
Say10
Posted: Tue Jun 27, 2006 01:40 AM
Man Eric, didnt waste any time..
Staff Officers
Posted: Tue Jun 27, 2006 02:04 AM
who me Shocked
Posted: Tue Jun 27, 2006 03:37 AM
Hey I'm Eric too. and no I'm not wasting time on this. I want to be able to blind those idiots that keep cutting me off.(jk) I just want to get it done so I can go on a night run soon.
azhunter
azhunter
Posted: Wed Jun 28, 2006 04:39 AM
Here's a typical relay set up. based on a 12v 20/30 amp pn# 0 332 204 150 This relay can be used in the normally open or normally closed position based on witch terminal you use in the middle.
Hope this helps. If I've goofed up, please feel free to criticize
Posted: Wed Jun 28, 2006 09:26 AM
i do not have a relay for the lights. only for the ultra cheesy air fn horn i got suckered into purchasing....
i will take pics of my set up wed and post em.... Very Happy
azhunter
azhunter
Posted: Wed Jun 28, 2006 05:38 PM
NOTHING ATTRACTS ATTENTION MORE THAN "LA CUCARACHA" IN THE MIDDLE OF THE DESERT Very Happy
No new posts VW Volkswagen & Baja Bug General Discussion Need Opinions On Light Bar
62 57baja 113903 Re: Need Opinions On L...
 Sun May 24, 2015 04:28 AM
69yellowbaja View latest post
what do you use
4 bdrdunes 3891 Baja bug rear led ligh...
 Thu Dec 18, 2014 03:55 AM
No new posts VW Volkswagen & Baja Bug General Discussion oil light
electrical
5 terribletommy 3016 oil light
 Thu May 22, 2014 08:56 PM
No new posts VW Volkswagen & Baja Bug General Discussion Brake light switch?? 3 sandbuggy 4000 Re: Brake light switch...
 Sun Nov 17, 2013 08:21 PM
No new posts VW Volkswagen & Baja Bug General Discussion best way to mount a light bar or roof rack? 7 woodin 15220 best way to mount a li...
 Mon Feb 07, 2011 03:31 AM
woodin View latest post
