Visitors: 136
Total: 136
05: Home
11: Event Calendar
40: Links
96: Links
107: Event Calendar
110: Links
KC's vert
Posted: Tue Mar 04, 2008 03:02 AM
kcnaz wrote:
Hedrock wrote:
KC... That's how my back bumper started... Cool
I have looked at your bumper and am not sure what part ya left. Was it the style that mounted to the top of the stock shock towers?
Yes... same as in pic. First I cut it in 1/2 right up the middle and cut the "J" or down tubes that went to the lower mount off. The part that went to the upper shock mount is now attached to my upper frame rail after a little trimming. A couple of straight tubes to connect the 2 sides together and last but not least a piece from my class 11 cage kit for the top tube... There ya have it Wink .
Sample
Sample
Posted: Thu Apr 17, 2008 01:24 AM
How is KC's car coming along?
Posted: Thu Apr 17, 2008 02:13 AM
he's a member of another site and doesn't post here any more.....
Posted: Thu Apr 17, 2008 05:17 AM
He's still around... I heard his wife was keeping him Busy... Wink
Posted: Thu Jun 12, 2008 02:05 PM
Not much progress on the car but the homestead is looking better. Smile
Striped the car down flipped the pan to finish welding ,sealing and coating the bottom. Renforced the engine frame horns and brushed on 2 coats of HURCULINER . Got the rear torsion ready for reassembly and am working on the front, 4x1.75 CM trailing arms. Sould get the spindles back today, had to have the shim cup taken down to get them to mate with the long arms.
on hold baja build
"when I nod my head, HIT IT"
Posted: Thu Jun 12, 2008 02:13 PM
New spread sheet data. makes moma happy.
Spent 10182.1
Sold 6839.51
TOTAL EXPENSE
3342.59
on hold baja build
Posted: Wed Sep 03, 2008 02:26 PM
Frame horn extension
Adjustable tranny mount
Wider torsion,this mod takes the stub axle farther out on the axle, farther out on a 25 degree line makes 24" of travel.
on hold baja build
Posted: Sat Oct 25, 2008 04:56 PM
Ever here that saying "when life throws you lemmons make lemmonaide'?
Well I am in the process of making lemmonaide............I'LL BE BACK.
on hold baja build
fast_1
fast_1
Posted: Sat Oct 25, 2008 07:04 PM
Good luck with that lemonade!
Posted: Tue Dec 23, 2008 07:40 PM
New parts for the front end. Soon as I am in the new house I am getting back to work on this car with a new plan.
on hold baja build
Posted: Wed Dec 24, 2008 09:20 AM
Ok, what is it...?
Posted: Wed Dec 24, 2008 12:18 PM
welcome back......looks like your going a-arm...?
Posted: Wed Dec 24, 2008 04:27 PM
rear bulkhead
front bulkhead,pre drilled for steering rack
This is the seup on another car,
front
back, the bulkheads are 15 degrees up from the level plane of the rest of the car.
on hold baja build
fast_1
fast_1
Posted: Wed Dec 24, 2008 06:23 PM
What kind of rack are they using on that other car?
Posted: Wed Dec 24, 2008 09:52 PM
Fortin powered.
on hold baja build
230 Hedrock 124438 Hedrock's 'vert projec...
 Wed Dec 17, 2014 04:52 AM
No new posts VW Volkswagen & Baja Bug General Discussion 69 vert standard 6 jamesr6168 3589 Re: 69 vert standard
 Wed Apr 04, 2012 05:03 AM
ghettodish View latest post
