Latest: xbluegto
Overall: 3573
Visitors: 199
Total: 199
18: Home
80: Home
96: Event Calendar
148: My Account
157: Baja Forums
164: Baja Forums
167: Home
170: Baja Forums
171: Baja Forums
172: Baja Forums
177: Baja Forums
178: Baja Forums
179: Baja Forums
180: Baja Forums
181: Baja Forums
182: Baja Forums
184: Baja Forums
187: Baja Forums
188: Baja Forums
189: Baja Forums
190: AMAZON.com
197: AMAZON.com
198: AMAZON.com
KC's vert
Posted: Mon Jan 14, 2008 06:16 AM
kcnaz wrote:
Yep I was looking at some othe cars also. The difference is this is a real convertible with a lot of extra stiffners in the back. the donor piece I am welding in back there has alot more clear fender space. I'll make it work. Your right its gonna be and is a fun challenge
I think that's why we all do it Smile .
Posted: Wed Jan 16, 2008 04:46 AM
Are you giong to keep your torsion bars or are you going to go with coils? What size torsion bars are you using?
Posted: Wed Jan 16, 2008 04:50 AM
I have the 944 bars in it now. Somebody said 23mm but I am gonna mic em. Mark @ BCR said I would twist out the inner splines on the torsion housing if I played rough, so the coil over will be an upgrade afta I get the car running. Tomorrow is friday for me..I am working a 4-10 schedule and I hope to get some work done on the car on my days off.
on hold baja build
"when I nod my head, HIT IT"
Posted: Wed Jan 16, 2008 04:54 AM
Good luck and have fun... Keep us posted Smile
Posted: Mon Jan 21, 2008 11:41 PM
Refit the body and more stuff in the way...I know solve it right?
on hold baja build
Posted: Mon Jan 21, 2008 11:51 PM
Hey give me your thoughts on this idea. I am thinking I want to redrill the big frame horns holes and drop the tranny down 1/2". I have the room at the cv's.
on hold baja build
Posted: Tue Jan 22, 2008 12:23 AM
I did the same with mine, if there is a will there is a way, that and a big fricken hammer helps too Laughing
Posted: Tue Jan 22, 2008 12:24 AM
You lowered the rear mount? All these little details.........
on hold baja build
Posted: Tue Jan 22, 2008 01:48 AM
Leather... That's not how you fix everything is it???
Posted: Tue Jan 22, 2008 05:49 AM
Heck, you could completely hack off the rear frame horns if you're in that deep already. You could fabricate a new set up from 1-12" tubing and tie in into your cage for additional support. That way, you could set it up from scratch and have it EXACTLY the way you want it.
Posted: Sat Jan 26, 2008 04:03 AM
IT WORKED....
Droped the motor mount 1/2 inch, the axles are now at 12 degrees. could have gone a little more but I got what I wanted,,the valve cover is off the rear deck.
Right side before and after....
Left side before and after...
The plugs...
on hold baja build
Posted: Mon Feb 18, 2008 04:40 AM
Got to use my tubing bender today, not sure Iam totaly happy with it. But I was able to get the bottom support rail in.....its not complete as I will grind and blend the welds in. I either have to widen my front end again or get wheels with zero offset.
on hold baja build
Posted: Mon Feb 18, 2008 04:45 AM
How wide is your beam now?
Posted: Mon Feb 18, 2008 04:47 AM
Posted: Mon Feb 18, 2008 04:49 AM
I think its about 4" , not exact. The wheels are offset to the inside about 3", I have been searching for different wheel, I found that the G-Class Mercedes has the 5x130 bolt pattern. 8x16" Rubicon
on hold baja build
230 Hedrock 110498 Hedrock's 'vert projec...
 Wed Dec 17, 2014 05:52 AM
No new posts VW Volkswagen & Baja Bug General Discussion 69 vert standard 6 jamesr6168 3104 Re: 69 vert standard
 Wed Apr 04, 2012 05:03 AM
ghettodish View latest post
