Author |
Message |
cperry2704
Post subject: lift
Posted: Sun Jan 06, 2008 08:08 AM
what is the best way to get a few inches of lift on a ball joint baja? cut n' turn? lift spindles? weld in adjusters?
any thoughts? or experience? and how is the ride effected?
Jimmyjack
Post subject: Re: lift
Posted: Sun Jan 06, 2008 06:07 PM
I just did a cut and turn. Best part? It's free..... but a pain. And it's a s stiff as a board.
_________________ Noone is ever COMPLETELY worthless; they can always serve as a bad example. I\'ll prove it, watch this....
+2
Posted: Sun Jan 06, 2008 06:32 PM
how do you do a cut and turn?
Jimmyjack
Posted: Sun Jan 06, 2008 11:49 PM
In a nutshell: You use a 3 or 4 wheel pipe cutter (rented it for $8) and cut the center section of the torsion tubes or beams. I'm not sure hwat they're called.  You rotate them up a 1/4 or less and weld them shut.
I jacked up the front of the car under the pan and I measured 3" out from the center "dimple" each way and cut there. I made a line across the tube and then measured 1.25 " up (I think) as a reference. Then I rotated the center section to the mark and had my buddy tack it. Repeated it for the bottom. It really helps to clamp a piece of angle iron on the torsion bar to align the cut pieces. They'll resist everything you do to make them straight.
After they were tacked together I stitch welded the cuts. Let them cool and finished the cuts, ground and painted.
I didn't go quite 1/4 turn cos it was getting pretty tight so I backed off a little bit.
You need a big pipe wrench and a cheater bar.
Swine
+1
Posted: Mon Jan 07, 2008 01:24 AM
How soon are you looking to do this? I'm going to be replacing my front end that has less than a 1000 miles (mostly street) on it.
Ball Joint lifted about 3 - 4 inches with adjusters.
cperry2704
Posted: Mon Jan 07, 2008 04:18 AM
well i want to do this soon, i am just wondering about the ride quality, between cuting and turning, a spindle lift, or weld in adjusters...or is it pretty much all the same ride? STIFF!
+3
Posted: Mon Jan 07, 2008 05:01 AM
If you cut and weld or wild in adjusters do one tube at a time.
The raised spindles should keep the ride pretty close to stock but cost alot more.
Swine
+1
Posted: Mon Jan 07, 2008 03:40 PM
The ride is actually pretty good, I'm running some inexpensive coilover shocks I got from Chirco and they also built the front end.
cperry2704
Posted: Tue Jan 08, 2008 12:06 AM
so cutting and turning, with some decent shocks...the ride wont be too bad?
Jimmyjack
Posted: Tue Jan 08, 2008 01:54 AM
Well it's pretty freekin' stiff. And it's more responsive when I turn the wheels. It used to just slide and drift. Also the 1st time I tried to launch my rail it nosedived into the dirt. Now the front doesn't come down so soon, but it's still stiff. Even without shocks it beats me up.
Sample
+1
Posted: Tue Jan 08, 2008 02:00 AM
Jimmyjack wrote: |
Well it's pretty freekin' stiff. And it's more responsive when I turn the wheels. It used to just slide and drift. Also the 1st time I tried to launch my rail it nosedived into the dirt. Now the front doesn't come down so soon, but it's still stiff. Even without shocks it beats me up. |
So it is really stiff then? My '66 front is cut and turned (not by me). I have only driven it around the block at 15mph max, so I didn't really notice the ride yet. It does have those cheap coilover shocks though.
Jimmyjack
Posted: Tue Jan 08, 2008 05:00 AM
You Sample from Wheeling Az? If so I'm the same JimmyJack. I sold my blazer tho....
I weigh 240 lbs and I jump up and down on the front end and it barely moves. I aired my tires down to compensate.
Sample
+1
Posted: Tue Jan 08, 2008 05:11 AM
Jimmyjack wrote: |
I weigh 240 lbs and I jump up and down on the front end and it barely moves. I aired my tires down to compensate. |
I am the same person. I too no longer have a blazer, good to see you.
cperry2704
Posted: Tue Jan 08, 2008 06:14 AM
so when cutting and turning, will i need any new parts to make the front end work? or should it be ok with all the stock parts?
+3
Posted: Tue Jan 08, 2008 06:19 AM
cperry2704 wrote: |
so when cutting and turning, will i need any new parts to make the front end work? or should it be ok with all the stock parts? |
Possibly longer shocks.
