Visitors: 168
Total: 168
07: Event Calendar
24: Home Page
27: Home
73: Event Calendar
79: My Account
80: Event Calendar
117: Event Calendar
120: Pictures
129: Event Calendar
158: Baja Forums
166: Event Calendar
168: Baja Forums
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Anti-theft: any ideas?
Post Post subject: Anti-theft: any ideas?
Posted: Wed Dec 19, 2007 05:06 AM
Any little tips/tricks to help keep my ride from getting jacked when it's parked out and about? It'll be garaged at home, so I'm really thinking more like parking lots, etc.
I've got a metal fuel line running along the tunnel. I was thinking of a discreet fuel shutoff under the seat. I was also thinking of one of those battery cutoffs like in boats, that takes the plastic "key". I'd prefer to not have to mess with the motor when I get out (obvious).
Just curious if anyone had any ideas.
PS- I've got no tunes or anything of value inside. I just don't want someone to drive off in the thing.
Post Post subject: Re: Anti-theft: any ideas?
Posted: Wed Dec 19, 2007 05:35 AM
Discreat switches work but can frustrate the #@$! out of you if you hit 'em by accident!
Posted: Wed Dec 19, 2007 05:43 AM
THEY MAKE A BRAKE LOCK THAT HOOK INLINE WITH BRAKE LINES, CHIRCOS SELLS THEM I THINK!! I HAVE NO ROOF ON MINE, SO I,M DOING THAT AND A VERY LOUD ALARM!!!
Posted: Wed Dec 19, 2007 05:45 AM
BY THE WAY WERE HAS DON BEEN!!HAVN,T HEARD FROM HIM SINCE THE CAR SHOW!!
shpuz
shpuz
Posted: Wed Dec 19, 2007 05:47 AM
hmmm... maybe you should try this
www.youtube.com/watch?v=hSbjgXbDUzo
thought it was funny Smile
but the gas cutoff souds like a pretty good idea. i dont see why it wouldnt work.
Quote::
Posted: Wed Dec 19, 2007 05:54 AM
Shocked Shocked THATS FUNNY RIGHT THERE!! CAN YOU SEE SOMEBODY THINKING THEY ARE GOING FOR A JOY RIDE, AND THEN,,,,,,, (I LITTLE HARD ON THE TIE RODS THOUGH!! Laughing
ajeden
ajeden
Posted: Wed Dec 19, 2007 06:04 AM
HI
Try the discreat switch. Break into a wire taking power to the coil and then route it to the switch.
Or, as friend of mine had. A big thick chain and padlock; this was attached to his seat and then the steering wheel.
Better than that, electrify it and nuke anyone who tries to steal it!!!!!!!!!
shpuz
shpuz
Posted: Wed Dec 19, 2007 06:07 AM
OR... why dont you just buy some sort of small tool box with a lock, and an easily removable steering wheel, and just lock the steering wheel in the box while your gone? dunno.... might work!
Posted: Wed Dec 19, 2007 02:37 PM
Get a racing style steering wheel quick disconnect and just take the steering wheel with you when you go some where.
Posted: Wed Dec 19, 2007 04:00 PM
I pull the rotor out of the distibutor. Its obvoius, but who will have another rotor to put back in to steal it?
I guess I am going to have to get more serious about this too. I have thought about welding a tab on the frame and the steering column running a short chain that I can padlock to keep the wheel from turning.
Somebody recommended this but here is how to wire a dead short to save your buggy
First you must install a circuit breaker after the Key (or On/Off switch)
Then from the hot side of the coil (#15 or +) connect a new wire from the coil to one side of a simple on/off switch. The other side of this switch is connected to ground. That's it your done.
Now if the would be thief connects his jumper wire to the coil and a hot wire. He creates a dead short and most likely melts his jumper wire and burns his fingers. Before he can try again he must figure out which one of the wires is shorted and disconnect it. Which wire goes to the distributor and reconnect it. This all takes time, so more then likely he will move on to easer Pickings.
When you want to start your car, you must remember to flip the hidden switch. If you forget the circuit breaker will pop and then after flipping the hidden switch, just turn the key off and back on to reset the circuit breaker.
We some times change the wiring slightly. Instead of our new wire going to ground, we connect it to a hidden horn. The switch is left on and when the jumper wire is used it blows the horn until disconnected. You could use both systems if you so desire.
Posted: Wed Dec 19, 2007 05:12 PM
Quite a good idea Leather. If you run a MSD, there is an ignition kill built into it also.
shpuz
shpuz
Posted: Wed Dec 19, 2007 08:03 PM
or.. just park it infront of another car/wall or on the curb. pretty sure the average theif isnt going to find reveres in the bugs. hehe.
Posted: Thu Dec 20, 2007 01:32 AM
I think Leather is done with MSD's... Wink
Posted: Thu Dec 20, 2007 01:35 AM
kill switch and alarm.... Wink
23 tdubs-83 11691 Re: Ideas to Start a B...
 Fri Dec 17, 2010 06:23 PM
DeathBug View latest post
No new posts VW Volkswagen & Baja Bug General Discussion front bumper ideas 7 danjones333 4999 front bumper ideas
 Tue Feb 02, 2010 07:26 AM
NAXZ View latest post
No new posts Projects and Builds NEED IDEAS
NEED IDEAS
8 everardo 4772 NEED IDEAS
 Wed Sep 23, 2009 09:25 AM
No new posts VW Volkswagen & Baja Bug General Discussion Fuel Filler Ideas? 4 catchbats 6563 Fuel Filler Ideas?
 Sat Jul 11, 2009 09:04 AM
57baja View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Pics of your stereo systems bug owners i need ideas! 8 bajamtbiker 7297 Pics of your stereo sy...
 Sat Jul 04, 2009 05:31 PM
Brettucks View latest post
