Latest: hulkbaja
Overall: 3594
Visitors: 105
Total: 105
01: My Account
06: My Account
09: Pictures
11: Event Calendar
13: Event Calendar
45: Pictures
64: Event Calendar
91: Pictures
95: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- alternator
alternator
tigerextra
tigerextra
Post Post subject: alternator
Posted: Mon Dec 03, 2007 06:09 AM
so im thinking ahead about an alternator conversion for the 1600dp (currently using stocky generator). Im looking at somthing 75amp or more. are there any donor car alternators we can use? (other vehicle makes) i have access to 5 or 6 junk/impound yards that are free to my plunderous hands. just dont feel like spending $250+ for an alt. setup
I enjoy every second of it!!
And a side note added,
all 6 of us agree!!
fatalifeaten
fatalifeaten
Post Post subject: Re: alternator
Posted: Mon Dec 03, 2007 09:01 PM
The thing to keep in mind here is that your alternator is also your cooling fan, so you have to fond one that has the through shaft for the fan too. I don't know specifically what other alternators will work, if any. Old Porsche units probably will...
--Harlan Ellison
tigerextra
tigerextra
Posted: Mon Dec 03, 2007 09:07 PM
hmm good point... say, what if i got rid of the stock fan shroud and tin, put in a big ole fan of my own in place, wired to the key so its always cooling?.... or is that delving too deep into the original setup? i know VW designed everything to work together like clockwork so mods to engine cooling and tin should be avoided... but maybe this could work just as well if not better??? Confused
all 6 of us agree!!
fatalifeaten
fatalifeaten
Posted: Mon Dec 03, 2007 09:15 PM
You can certainly give that a shot, but if you get a generic 75 amp alternator for a hundred bucks (for the sake of discussion, I'm not sure what they really run) , that leaves you 150 to get it right with the fan arrangement the first time. There won't be a second time because if it's not right at first you'll burn up your motor and be looking at more than the cost of an alternator...
caveat emptor
--Harlan Ellison
Posted: Mon Dec 03, 2007 10:04 PM
You can use a 63 amp GM alternator for $40 here
www.partsamerica.com/P...11&PTSet=A
And I have heard of people making an adapter chaft off of the back of the VW generator and going direct shaft drive to the GM alternator. You just gut the stock generator and the GM alternator site behind the fan shroud. In bajas and steet beetles you will have to cut the firewall for clearance.
OR..........
You could fab a bracket on the front of the motor and run a longer belt IF you can find room..
tigerextra
tigerextra
Posted: Wed Dec 05, 2007 11:30 PM
hmm its starting to look like the safest and easiest way is going to be with the overpriced VW alternator kit..
all 6 of us agree!!
28 seanoflinn1 11636 Re: Can Somone take a ...
 Mon Jun 14, 2010 11:07 PM
No new posts VW Volkswagen & Baja Bug General Discussion Wanted VW alternator core 2 bajawarrior 1750 Wanted VW alternator c...
 Sat Jun 27, 2009 10:21 PM
catchbats View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Alternator/charging dummy light 6 Sample 2152 Re: Alternator/chargin...
 Tue May 13, 2008 04:46 AM
57baja View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Swapped my gen out for an alternator 4 Jimmyjack 3188 Re: Swapped my gen out...
 Thu Jan 24, 2008 02:15 AM
Jimmyjack View latest post
