Visitors: 258
Total: 258
20: My Account
21: My Account
23: My Account
24: My Account
26: My Account
53: Event Calendar
85: Pictures
98: Event Calendar
101: My Account
102: My Account
109: My Account
119: Event Calendar
125: Event Calendar
133: Event Calendar
150: Baja Forums
155: Event Calendar
159: Event Calendar
163: Event Calendar
164: Baja Forums
166: Baja Forums
168: Baja Forums
169: Event Calendar
170: Baja Forums
171: Event Calendar
174: Event Calendar
178: Event Calendar
179: Baja Forums
180: Baja Forums
183: Baja Forums
184: Baja Forums
185: Baja Forums
186: Baja Forums
188: Baja Forums
189: Baja Forums
190: Event Calendar
191: Baja Forums
196: Baja Forums
197: AMAZON.com
198: AMAZON.com
202: AMAZON.com
204: AMAZON.com
205: AMAZON.com
206: Event Calendar
207: AMAZON.com
208: AMAZON.com
209: Baja Forums
210: Baja Forums
211: Baja Forums
212: Baja Forums
213: AMAZON.com
214: AMAZON.com
215: My Account
216: My Account
217: My Account
218: My Account
219: My Account
220: My Account
221: My Account
222: My Account
223: My Account
225: AMAZON.com
226: Event Calendar
227: AMAZON.com
229: AMAZON.com
230: Baja Forums
231: Baja Forums
232: Baja Forums
233: AMAZON.com
234: Baja Forums
235: AMAZON.com
236: Pictures
237: AMAZON.com
238: Baja Forums
239: AMAZON.com
240: Event Calendar
241: Baja Forums
242: AMAZON.com
243: Baja Forums
244: Baja Forums
245: Baja Forums
246: Baja Forums
247: AMAZON.com
248: AMAZON.com
249: AMAZON.com
250: AMAZON.com
251: Baja Forums
252: Baja Forums
253: Baja Forums
254: Baja Forums
255: Baja Forums
256: AMAZON.com
257: Baja Forums
258: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Chirco roll cage for Super got a question....
jeepnut7261
jeepnut7261
Post Post subject: Chirco roll cage for Super got a question....
Posted: Fri Nov 30, 2007 12:06 AM
OK, I have a 74 Super, yes I know it's a bear to Baja, but I am going to try anyway.
SO, can I use the 6 point roll cage advertised here from chirco to use as a base to build a tube front? Or do I need something heavier?
I've built stuff for Jeeps, so I can bend pipe and weld (grind too) and I am thinking of just copying a rail front end (sort of) to put an regular beetle front axle on.
So, any suggestions? (besides getting another year)
Flat learning curve............
DOGLESS HIPPIE!!!
oh, wait, I have a dog, uhh, or maybe cat, uhh, goldfish???? I don't think it's one of the kids....
Post Post subject: Re: Chirco roll cage for Super got a question....
Posted: Fri Nov 30, 2007 02:18 AM
probable a type-o...you wrote pipe...you mean tubing correct ?
sorry dont have a answer for your question.
Posted: Fri Nov 30, 2007 02:19 AM
I think it would be a good base. If you do that then you could easily convert the front end.
jeepnut7261
jeepnut7261
Posted: Fri Nov 30, 2007 02:32 AM
Yep, tubing. Embarassed
DOGLESS HIPPIE!!!
Posted: Fri Nov 30, 2007 04:32 AM
You should be able to use the cage. The only problem that you might run into is the front hoop hitting the dash, but it may not. The rear will fit for sure.
jeepnut7261
jeepnut7261
Posted: Fri Nov 30, 2007 04:37 AM
Front hoop? Do you mean the dash bar? Hey, cut and bend, then weld again!!
I am going to take the body off the pan this weekend, so I will have a better idea about reinforcing the pan for attachment too.
DOGLESS HIPPIE!!!
vwbill
vwbill
Posted: Fri Nov 30, 2007 11:57 PM
Some where I read supers bodys differ from standard bug by 1" between front fender and door. From door back they should be the same. Chassis differ at frame head. Not sure how your curved window and padded dash measure up though.
William
Posted: Sat Dec 01, 2007 12:54 AM
71 & 72 supers are the same from the dash back. The 73 & up im not so sure on the cage clearing the dash, but they do take the same doors so it might just clear.
tigerextra
tigerextra
Posted: Mon Dec 03, 2007 12:36 AM
an easier way to fab the front end for the link pin is to cut the McPherson crap off then weld on a link pin frame horn. thats what i did and am planning to have Bugzyla and gang strengthen all that into the cage. just make sure its all square. you can even give yourself another six inches or so in length depending onh your preference. . let me know if you have any questions!
I enjoy every second of it!!
And a side note added,
all 6 of us agree!!
jeepnut7261
jeepnut7261
Posted: Mon Dec 03, 2007 12:28 PM
OK, first question...
I have seen where others online have done that, where can I find a link pin pan?
DOGLESS HIPPIE!!!
Posted: Mon Dec 03, 2007 03:29 PM
You can buy just the frame head from Chirco
www.chircoestore.com/c...9rvi7uh6q0
tigerextra
tigerextra
Posted: Mon Dec 03, 2007 06:02 PM
this is a very simple and effective way of transforming your super into an IRS/link pin baja. just MAKE SURE ITS SQUARE! i cant stress that enough... also good welds are a plus. note in the pic that i drilled half inch holes in the frame head BEFORE i mounted it, then "spot welded" the holes to the pan. dont forget to grind and clean all contacting metal for good penetration. i also beefed up all contacting ends with a few thick welds for structure. also it is imperative that you strengthen the beam to the cage, not that this isint already very strong if you do it right, but you can never be too strong! good luck
>ask questions when you are unsure, cut once and measure fifteen times.
all 6 of us agree!!
Posted: Tue Dec 04, 2007 01:46 AM
Good job!!! Cool
tigerextra
tigerextra
Posted: Tue Dec 04, 2007 07:05 AM
Mykul wrote:
Good job!!! Cool
me? thanks mykul. i appreciate man Smile its got a long ways to go... have almost everything (except for suspension ca$h) then its goin together!!!!! two years and counting!
all 6 of us agree!!
25 Kreed 26199 3" Body Lift, Class 11...
 Tue Apr 10, 2018 02:26 PM
Kreed View latest post
18 Dirtjunkie 6622 Official 2016 Hassaymp...
 Tue Nov 08, 2016 02:49 AM
42 wideopenmotorsports 14323 ROLL CALL - HASSAYAMPA
 Sun Nov 08, 2015 03:14 AM
No new posts VW Volkswagen & Baja Bug General Discussion Baja Bug Modification question 4 Ailill 7918 Baja Bug Modification ...
 Mon Apr 13, 2015 04:07 AM
Ailill View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Lifting a super beetle front end 1 72sbbaja 2161 Re: Lifting a super be...
 Wed Jul 02, 2014 04:42 PM
