Visitors: 101
Total: 101
21: Pictures
32: Home
62: Event Calendar
63: Pictures
95: Pictures
97: Pictures
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- 6'' wider beam
6'' wider beam
cperry2704
cperry2704
Post Post subject: 6'' wider beam
Posted: Sun Nov 04, 2007 11:44 PM
so if i were to buy the 6'' wider beam and frame head from chirco, are there any other parts i need? can i still use the stock arms? different size front shocks?
Wiggins
Wiggins
Post Post subject: Re: 6'' wider beam
Posted: Mon Nov 05, 2007 06:27 PM
You will need tierods, upper and lower beam supports, new beam bushings and probally a couple of steering items depending on how you want to set up your steering.
General Manager
www.chirco.com
www.chircoestore.com
Posted: Mon Nov 05, 2007 11:06 PM
And an extra set of torsions to cut down, the warrior beam are not set up so you can just use one set of torsions.
Posted: Tue Nov 06, 2007 01:05 AM
A roll cage to hook it into. ou get to the point were you can start bending stuff with a wider beam with out proper support.
25 Kreed 26748 3" Body Lift, Class 11...
 Tue Apr 10, 2018 02:26 PM
Kreed View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Bent beam 1 cperry2704 1453 Bent beam
 Tue May 30, 2017 03:38 AM
JWHracing View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Need a rebuild on my link pin beam 2 wideopenmotorsports 2886 Re: Need a rebuild on ...
 Wed May 18, 2011 01:38 AM
No new posts VW Volkswagen & Baja Bug General Discussion bearing in side bj beam 11 1969Type1BAJA 5299 Re: bearing in side bj...
 Tue Feb 23, 2010 06:56 AM
1969Type1BAJA View latest post
No new posts VW Volkswagen & Baja Bug General Discussion cut the center beam 1 1969Type1BAJA 1721 Re: cut the center bea...
 Sun Dec 06, 2009 08:33 PM
