Visitors: 238
Total: 238
04: Pictures
11: Pictures
12: Pictures
13: Pictures
18: Pictures
21: Pictures
22: Event Calendar
25: Pictures
28: Pictures
29: Pictures
30: Pictures
33: Pictures
54: Pictures
55: Pictures
67: Pictures
74: Pictures
77: Pictures
82: Pictures
84: Pictures
85: Pictures
89: Pictures
99: Pictures
122: Pictures
134: Pictures
137: Pictures
148: Pictures
149: Pictures
150: Baja Forums
162: Baja Forums
169: Pictures
171: Pictures
172: Pictures
174: Pictures
175: Pictures
177: Baja Forums
178: Baja Forums
179: Pictures
182: Baja Forums
185: Baja Forums
186: Baja Forums
187: Baja Forums
188: Pictures
196: Baja Forums
197: Baja Forums
198: Baja Forums
199: Baja Forums
200: Baja Forums
202: AMAZON.com
204: Baja Forums
205: Baja Forums
207: Baja Forums
208: Baja Forums
209: Baja Forums
210: Baja Forums
211: Baja Forums
212: AMAZON.com
213: Baja Forums
214: Pictures
216: Pictures
217: Pictures
218: Baja Forums
219: AMAZON.com
220: Baja Forums
221: AMAZON.com
222: Baja Forums
223: Pictures
224: Baja Forums
225: Baja Forums
226: Baja Forums
227: Pictures
228: Baja Forums
229: Baja Forums
230: AMAZON.com
231: Baja Forums
232: AMAZON.com
233: Pictures
234: AMAZON.com
235: Pictures
236: Pictures
237: Baja Forums
238: Baja Forums
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- stock dist. to 009
stock dist. to 009
ljoe
ljoe
Post Post subject: stock dist. to 009
Posted: Sat Oct 20, 2007 06:33 PM
hi., Im a new member and Im glad i found this website something I'BEEN LOOKING for so long and I have a question I'm sure someone will be able to answer ., I have a '63 baja bug and we change the stock distribuitor for a 009 but since the change I notice a big change on the power and we check the timming a couple of times but still doe not have the same power i had with the stock one what you guys recomend me to do ? Rolling Eyes
T_Town_Baja
T_Town_Baja
Post Post subject: Re: stock dist. to 009
Posted: Sat Oct 20, 2007 06:49 PM
When you checked the timing, did you static time it or use a timing light?
With the 009's you need to set it's full advance with a timing light at about 3000RPM. The only real downside to the 009 dizzy is a small flatspot.
Another thing, is it a new 009? I would verify the points are good and within spec.
Blaine
ljoe
ljoe
Posted: Sat Oct 20, 2007 06:57 PM
Hey Blaine thanks for your fast reply and yeah I use static for timming check and that 009 is used I got it at a parts swapmeet and I will check the points and replace them with new ones
thanks for your info
ljoe
T_Town_Baja
T_Town_Baja
Posted: Sat Oct 20, 2007 11:14 PM
If you did only do static time, then you definetly need to check it with a timing light. The 009 dizzys tend to fluctuate in there timing advance. The static time is just a ball park to get the car running. You need to check it with a timing light at 3000 rpm's and set it to 28* (I beleive). Tighten it up and leave it be.
Blaine
MWDesigns
MWDesigns
Posted: Sun Oct 21, 2007 03:41 AM
I'm a big fan of the electronic points as opposed to the mechanical ones. Their a bit pricey but SO worth it in my opinion. No more adjusting every 500 miles Smile
www.michaelwhitedesigns.com
Graphic Designer,
Independent Amsoil Dealer
www.mwlubricants.com/
Army OIF Veteran
and general desert rat
'69 SLOOOW going project
Posted: Sun Oct 21, 2007 03:51 AM
i couldn't agree more.... Wink
ljoe
ljoe
Posted: Sun Oct 21, 2007 06:49 PM
thanks Blaine and michael for your help I'm glad I found this website were you find people with same interest in Bajas the one Im working on is a '63 full roll cage w/ 3'' lift kit but stock suspension and drivetrain but still be lots of fun to ride it with my 13 year old son.
I've been in a couple of races down in Ensenada Baja with a friend as a copilot and a couple of times as a driver thats how I end-up loving Bajas and be sure I will be visiting you guys very offten.
Thank you again for your help
kyle_pc_75
kyle_pc_75
Posted: Tue Oct 23, 2007 03:45 PM
I was wondering if they made something like an HEI upgrade for those dizzys. Do you have a link?
Posted: Tue Oct 23, 2007 03:55 PM
Pertronix makes one for the 009
www.chircoestore.com/c...cts_id=997
and the stock vacuum advance distributors
www.chircoestore.com/c...cts_id=998
Or you can go with a multiple spark discharge ignition which will give you a more complete fuel burn and more hp
www.thesamba.com/vw/cl...?id=444793
MWDesigns
MWDesigns
Posted: Tue Oct 23, 2007 05:44 PM
Thank BugZyla, he gave you a lot more info than i could've. I was only thinking about the Petronix one.
Smile thanks BugZyla Smile
Graphic Designer,
Army OIF Veteran
1 suburbangorilla 3299 CONVERTING '71 STOCK B...
 Wed Apr 01, 2015 11:51 AM
No new posts VW Volkswagen & Baja Bug General Discussion Wheel travel stock vs. 3x3 6 ghettodish 6837 Wheel travel stock vs....
 Tue Jan 31, 2012 02:57 AM
No new posts VW Volkswagen & Baja Bug General Discussion Does any one local to Chandler AZ stock 7x15 tires? 3 tobiism 8739 Does any one local to ...
 Wed Dec 14, 2011 02:46 AM
No new posts VW Volkswagen & Baja Bug General Discussion rack & pinion w/stock fuel tank 0 ghettodish 1873 rack & pinion w/stock ...
 Wed Nov 09, 2011 07:44 AM
ghettodish View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Does the stock speedometer have a light? 2 pschneider 2398 Re: Does the stock spe...
 Wed Jun 02, 2010 04:45 AM
nukeworker View latest post
