Visitors: 85
Total: 85
09: Pictures
11: Event Calendar
20: Event Calendar
31: Event Calendar
44: Event Calendar
60: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- water cooled or air
water cooled or air
4play
4play
Post Post subject: water cooled or air
Posted: Mon Oct 08, 2007 03:19 AM
I have ben looking at a lot of sites and I would like to go water cooled but Iam not sure I wont to go with a suby, witch seems to be the most popular, I do have a nissan 2.0 witch I would like to try, Any info and or personel experiences. would help.
Post Post subject: Re: water cooled or air
Posted: Mon Oct 08, 2007 04:35 AM
my opinion is bias....22r
By fasthoe, shot with DMC-LZ2 at 2007-09-23
BajaMan87
BajaMan87
Posted: Wed Oct 10, 2007 02:56 AM
in your opinion which one has more power and is better suited for your vehicle
Drive it like you stole it.
1972 VW Super Beetle BAJA
Posted: Wed Oct 10, 2007 06:07 AM
its alot more work that has to be done on a h2o engine, vdub, just swap it out...its a personal decision in what you want to run. i made my decision on that i wanted something that would be reliable and little mantenance. plus, this has about 130 to 150 hp and close to 200 torque Cool
4play
4play
Posted: Fri Oct 12, 2007 03:19 AM
I am looking for cheep reliable horsepower, switching to water cooled is not a big deal,mostly wont reliabilety. O and hourse power!
MWDesigns
MWDesigns
Posted: Fri Oct 12, 2007 06:21 AM
if you want HP and your choise is between a Nissan and a Toyota I'd definitly go with the 22R Toyota. But I'm a little bias too! (Tacoma owner)
www.michaelwhitedesigns.com
Graphic Designer,
Independent Amsoil Dealer
www.mwlubricants.com/
Army OIF Veteran
and general desert rat
'69 SLOOOW going project
Posted: Sat Oct 13, 2007 01:45 AM
you what reliable, hows this...i bought my 22r with over 230k miles on it, i had daryll's engine guy go through it and when he miced the crank it was perfect...all he did was repolish the journeys.... Cool
ajeden
ajeden
Posted: Thu Oct 18, 2007 04:35 AM
Hi
I am also interested in changing to h2o. I have been told that a Jetta 1800 is a good option.
Also with baja's being light on the front end, will a water cooled engine be heavier? Shocked
Posted: Thu Oct 18, 2007 04:35 PM
ajeden wrote:
Hi
In a word......YES
The engine is heavier, then add in the weight of the adapter plate, radiator, coolant hoses, coolant, engine mounts, etc. Then add in the complexity of the radiator mounting, running of coolant hoses, electric fan, fabricating engine mounts, etc. (did I leave anything out Rob?)
Is it worth the weight and extra work? Since a lot of people do it, I would say probably. I had a FAT 1600 Rabbit engine in my old rail/class 10 car; it was expensive, but fun.
In Mexico, they say the Jetta engine bolts up to a Mexican 091, so you can save on the adapter, if you can get a trans.
Posted: Fri Oct 19, 2007 02:46 AM
very good don, the only other thing to think about is running new wire...i hate wiring... Evil or Very Mad
4play
4play
Posted: Fri Oct 19, 2007 03:21 AM
I have thot about this for a long time, And it looks to be a little time consuming and expensive but worth it. Who sells adapter plates, other than kep.
Posted: Fri Oct 19, 2007 03:27 AM
yes to takes a little more time, but you will like the difference. as far a cost, after selling off my vdub stuff, i have about 1600,1700 in the swap total. Very Happy Cool
heckermachine.com/
ajeden
ajeden
Posted: Sat Oct 20, 2007 05:05 AM
Hi Valid reasons. So if I decide to go ahead, what can I do, which is not too expensive, regarding the heavier rear; which will make the front even lighter?
Also, if I decide to stick with this engine; a bigger bore? But how far can you go? I want pretty good MPG + more power/torgue.
Thanks
Posted: Sat Oct 20, 2007 02:39 PM
if your worried about gas mileage, leave it stock and just add headers and a better intake manifold, maybe upgrade the cam shaft for more torque...
No new posts Projects and Builds Building a Baja for my son, new to air cooled!
33 thedipstick 19864 Building a Baja for my...
 Tue Apr 07, 2015 11:08 PM
thedipstick View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Water proofing distributor
Heat shrink?
3 ButchW 2527 Re: Water proofing dis...
 Wed Oct 02, 2013 04:00 PM
ButchW View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Water bug 0 perrib 2739 Water bug
 Sat Nov 10, 2012 03:43 AM
No new posts Events and Get Togethers World Wide Air Cooled VW show in downtown Mesa 7 perrib 4486 Re: Air Cooled VW show...
 Thu Apr 15, 2010 11:39 PM
No new posts VW Volkswagen & Baja Bug General Discussion return to air cooled or change water cooled engine 7 ajeden 5223 Re: return to air cool...
 Sun Aug 17, 2008 11:11 PM
ajeden View latest post
