Visitors: 107
Total: 107
02: Event Calendar
20: Event Calendar
24: Event Calendar
26: Pictures
41: Event Calendar
48: Home
59: Event Calendar
61: Links
62: Event Calendar
82: Pictures
86: Event Calendar
90: Event Calendar
101: Pictures
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- super bug
super bug
cjsanders
cjsanders
Post Post subject: super bug
Posted: Fri Oct 05, 2007 01:27 AM
what would it take to convert a super into a good baja...i no where one is with a stroker moter and i can get it for free
I LOVE BAJAS
fatalifeaten
fatalifeaten
Post Post subject: Re: super bug
Posted: Fri Oct 05, 2007 01:29 AM
A miracle. Supers are strut cars and a beyotch to convert. If the stroker motor's good, get the car and part it for the motor and trans. They'll drop right into a torsion beam pan car, which is what yer gonna want to start with
--Harlan Ellison
cjsanders
cjsanders
Posted: Fri Oct 05, 2007 01:34 AM
gotcha.....thanks
I LOVE BAJAS
vwbill
vwbill
Posted: Fri Oct 05, 2007 04:30 AM
Super bugs have a 1” stretch in the front sheet metal (door frame forward) from 71-73.5 after 73.5 they had a curved windshield. If you are looking at a flat windowed super and cut away the front sheet metal from the door pillar forward then put in a frame to support the axel beam, I think you would have the start of a baja. Just my opinion and some work for you.
William
T_Town_Baja
T_Town_Baja
Posted: Fri Oct 05, 2007 05:11 AM
If you are gonna get a super, plan for at least $500 to convert it over to LinkPin.
To baja a super, you really only have two options - both are alot of work.
First, cut off the head at the pan, weld in a LP frame head and build it to a normal LP front end - this will require some addition supports added, IE cage.
The other option, is to use the super's front supports and build up an A-arm front suspention.....This option will cost a lot more $$$, but be pretty nice. I wouldnt mine trying it....
Blaine
No new posts VW Volkswagen & Baja Bug General Discussion Lifting a super beetle front end 1 72sbbaja 2161 Re: Lifting a super be...
 Wed Jul 02, 2014 04:42 PM
No new posts Projects and Builds my 72 super project 2 vtbaja 2849 my 72 super project
 Tue Jan 21, 2014 10:34 PM
No new posts VW Volkswagen & Baja Bug General Discussion super baja question 9 vtbaja 4374 super baja question
 Thu Aug 29, 2013 11:07 PM
No new posts VW Volkswagen & Baja Bug General Discussion super beetle baja bug 4 vtbaja 4942 Re: super beetle baja ...
 Wed Aug 14, 2013 04:48 AM
No new posts VW Volkswagen & Baja Bug General Discussion Super beetle vs standard baja kit 3 Voiden 3151 Super beetle vs standa...
 Thu Sep 13, 2012 07:35 AM
