Visitors: 116
Total: 116
41: Pictures
45: Pictures
61: Pictures
76: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- new brakes,not satisfied
todd
todd
Post Post subject: new brakes,not satisfied
Posted: Sun Sep 02, 2007 05:12 PM
hey guys...well my dad and i took the baja on its mayden voyage yesterday(around the block)everything feels real tight..but im not satisfied with the brakes...everything is new.upgraded the front brakes to disc..but it dosent stop very good and i couldnt get them to lock up forward and a little lock up in reverse...
any ideas ...it has a new master,wheel cylenders in rear ,new rubber lines and disc in front...everything blead out good...
do these things have good stopping or is this as good as it gets,,,thanks.
todd
Post Post subject: Re: new brakes,not satisfied
Posted: Sun Sep 02, 2007 05:39 PM
I have all wheel disc brakes nd it will stop on a dime and give 3 cents back.
Make sure you have a little free play when the brake is up. also replace your ruber lines with new lines. You might need to add a praportioning valve to your car so you suply more prsure to your front brakes. mke sure ou have the bleed scres on the highside bleed as air can pocket in the calipurs.
Alos just stand on the brake it should not move at all. if it drops etc. you have another problem.
No new posts Club AzBaja (Arizona Chapter) bj front disk brakes with raised spindles 2 vwboat 3137 Re: bj front disk brak...
 Thu Dec 13, 2012 03:03 PM
No new posts VW Volkswagen & Baja Bug General Discussion front brakes on a sandrail 2 Thuff 2173 Re: front brakes on a ...
 Thu Jan 29, 2009 03:11 AM
No new posts VW Volkswagen & Baja Bug General Discussion Emergency Brakes With 3x3 Arms 0 57baja 1869 Emergency Brakes With ...
 Sat Sep 20, 2008 07:48 AM
57baja View latest post
No new posts VW Volkswagen & Baja Bug General Discussion brakes??? 0 KrazyKarl 1169 brakes???
 Thu Jun 12, 2008 05:50 AM
KrazyKarl View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Brakes 3 caversmoon 1628 Re: Brakes
 Mon Aug 20, 2007 11:19 PM
klwdesigns View latest post
