Visitors: 76
Total: 76
63: Event Calendar
72: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Battery light
Battery light
ajeden
ajeden
Post Post subject: Battery light
Posted: Wed Aug 15, 2007 05:01 AM
Last night on my way home my battery light came on, very dim, but there. This morning the same.
I checked the alternator and where the cable is attached which feeds the battery; the reading was about 17 volts. I then checked the battery and the reading there was about 12 volts.
So, the alternator is charging the battery, but why the light?
This morning the light was again very dim, then off. Tonight when I left work it was off; then it came on.
I have noticed that the little cable that comes from the alternator into the loom can be moved slightly? Could there be a problem there. My alternator has what looks like a cover that can be removed?
Any ideas guys Crying or Very sad
fatalifeaten
fatalifeaten
Post Post subject: Re: Battery light
Posted: Wed Aug 15, 2007 06:27 AM
make sure the connections are all ticht, it sounds like something's loosening, and you're getting a fault indication from that. Check battery cables at both ends, they can work loose and cause an issue like this.
--Harlan Ellison
ajeden
ajeden
Posted: Wed Aug 15, 2007 05:12 PM
Thanks. Will do.
Posted: Thu Aug 16, 2007 03:11 AM
also make sure the cable itself is in good shape... Wink
ajeden
ajeden
Posted: Thu Aug 16, 2007 05:09 AM
Thanks. Going to chack everything a.s.a.p.
No new posts VW Volkswagen & Baja Bug General Discussion Need Opinions On Light Bar
62 57baja 93509 Re: Need Opinions On L...
 Sun May 24, 2015 04:28 AM
69yellowbaja View latest post
what do you use
4 bdrdunes 2659 Baja bug rear led ligh...
 Thu Dec 18, 2014 03:55 AM
No new posts VW Volkswagen & Baja Bug General Discussion oil light
electrical
5 terribletommy 1975 oil light
 Thu May 22, 2014 08:56 PM
No new posts VW Volkswagen & Baja Bug General Discussion Brake light switch?? 3 sandbuggy 2823 Re: Brake light switch...
 Sun Nov 17, 2013 08:21 PM
No new posts VW Volkswagen & Baja Bug General Discussion best way to mount a light bar or roof rack? 7 woodin 12496 best way to mount a li...
 Mon Feb 07, 2011 03:31 AM
woodin View latest post
