Visitors: 106
Total: 106
05: Contact Admin
11: Event Calendar
18: Event Calendar
27: Event Calendar
55: Event Calendar
60: My Account
61: Pictures
73: Event Calendar
79: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Having problems with weber dual carbs
ridinthedunes
ridinthedunes
Post Post subject: Re: Having problems with weber dual carbs
Posted: Thu Jul 19, 2007 11:24 PM
are all 4 barrels sync'd? or did you just do the from two (2&4), are you SURE the linkage is setup correctly? valves all adjusted properly? excellerator pumps working properly?
Maybe give, in detail, your engine specs, including distributor used, timing, valve lash, jetting (emulsion tube, air, main, idle), and maybe a quick example of how you tuned the carbs.
And I was thinking that only kads like such low pressure, thought that idf's were ok at 5lbs.......
elryano
elryano
Posted: Wed Jul 25, 2007 01:53 AM
i was told idfs only need 3 pounds maybe u need a pressure regulator
Posted: Mon Jul 30, 2007 05:22 PM
elryano wrote:
i was told idfs only need 3 pounds maybe u need a "GOOD" pressure regulator
No new posts Projects and Builds Swing Axle Dual Shocks 2 dave46 4376 Re: Swing Axle Dual Sh...
 Fri Sep 11, 2015 08:06 PM
dave46 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Dual carbs 11 sandbuggy 7594 Dual carbs
 Sun Jul 14, 2013 02:02 PM
No new posts VW Volkswagen & Baja Bug General Discussion Steering Box Problems 13 nukeworker 9188 Re: Steering Box Probl...
 Sun Jun 24, 2012 04:21 AM
nukeworker View latest post
No new posts VW Volkswagen & Baja Bug General Discussion duel weber 44s value 0 beachmaster 1311 duel weber 44s value
 Sun Nov 27, 2011 06:51 AM
beachmaster View latest post
No new posts VW Volkswagen & Baja Bug General Discussion weber style progressive carbs 2 cruzn57 3041 Re: weber style progr...
 Sat Apr 23, 2011 02:31 PM
cruzn57 View latest post
