Visitors: 125
Total: 125
65: Event Calendar
103: Event Calendar
118: Home
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- any reason why it aint doin a wheely
The following users give thanks for this topic Anonymous - Mon Apr 13, 2009 06:29 AM
milleraj119
milleraj119
Post Post subject: any reason why it aint doin a wheely
Posted: Mon Jun 04, 2007 06:13 AM
i have a stroked out 2387 with a 1971 3 rib bus trans and a hella strong kennedy clutch and iv tried and tried to do a wheely and the front end just wont come up i was wondering if anyone would no why. the tires rost hella but the front end wont come up.
Post Post subject: Re: any reason why it aint doin a wheely
Posted: Mon Jun 04, 2007 07:45 AM
Street or dirt? Clay Akin or Ruben Studdard shape? Confused
It's a good way to break it! Twisted Evil
milleraj119
milleraj119
Posted: Mon Jun 04, 2007 07:51 AM
baja bug tried doin it on the road like a million times i have 31 all terrains tires on
tigerextra
tigerextra
Posted: Mon Jun 04, 2007 08:08 AM
start by using gravity to your advantage and put all of your weight in the rear ie gas tank. pull the metal fenders and hood from the front, swap to fiberglass or carbonfiber, get short and wide rear tires with low air pressure for grip... if that doesnt work.... get an aluminum front beam... or my way, just buy motorcycle :)...... }Oh and try stuffing all the neighborhood kids in the rear seat by the gas tank for more weight, and if you flip it, just think, they will never bother you again.
I enjoy every second of it!!
And a side note added,
all 6 of us agree!!
coreyvdg
coreyvdg
Posted: Mon Jun 04, 2007 02:21 PM
If tires in the back are spinnin you're not gettin enough grip in the back obviously. Try lowering the pressure in your rear tires (not so much that the rim spins in the tire) and put some weight over the rear wheels. Sorry if this has been said didnt have time to read the whole thread.
www.nmsandrails.com
View user's profile Visit poster's website AIM Address MSN Messenger
milleraj119
milleraj119
Posted: Tue Jun 05, 2007 03:59 AM
thanks for the help i was just wondering becasue iv seen 1776cc baja that doo wheeles for blocks and i have double the horse power.
bajajon
bajajon
Posted: Tue Jun 05, 2007 04:28 AM
just put ruben studdard in the back u will barely have to touch the gas to do a wheely, plus u save in gas!
dang, I broke it again
Posted: Tue Jun 05, 2007 06:34 AM
do you have 3x3 arms on the car? ar you an IRS or Swing Axle Car? You could be geared to low with the Bus trans axle. Can you lif the front of the car off the ground with you and a buddy?
milleraj119
milleraj119
Posted: Tue Jun 05, 2007 08:06 AM
it is not a-armed in the front and it is irs and i can lift up the front end by by self not to sure if it geard to low or not but the bug is fuckin crazy fast i street raced one of the new mustangs and killed it and also a twin turbo toyota supra and also killed that so i have no idea why it wont come off the ground the gas tank is in the front or mabey because i have 15 inch tires up front with the beams not cut or anything and i have 31s in the back with the rear end lifted.
Posted: Tue Jun 05, 2007 08:58 AM
that would be rear arms. 2 you might have the highend HP but not the grunt to lift the front end. But from what you say the tires will spin, so you also have a traction problem. You might need to put some sticky street tires on it.
Jordynarz
Jordynarz
Posted: Wed Jun 06, 2007 05:22 AM
I heard that the Bus trans lifts more upward when accelerating. I heard it was good for climbing dune hills because it squats up instead of down. But Thats just what I heard.
Posted: Wed Jun 06, 2007 06:28 AM
that would be a bus transaxle with reduction boxes like Bugzilla has
Jordynarz
Jordynarz
Posted: Thu Jun 07, 2007 05:19 AM
Ok. Thanks. But that is different that the 3 rib bus.?
Posted: Thu Jun 07, 2007 07:11 AM
The bus that will lift the rear has reduction box's, so the axles rotate backwards and then the reduction boxes turn the wheels forward. That is what makes the rear end rise up. every thing else the car will squat down, It's just the way it is.
ridinthedunes
ridinthedunes
Posted: Sat Jun 09, 2007 05:51 PM
You should post your engine specs....could be setup for just top end and don't have the torque to pull it...
list your specs, cam, heads, valve size, port work, carbs, exhaust, distributor, ...anything you can think of.
No new posts VW Volkswagen & Baja Bug General Discussion thinkin of doin back way to sedona 4 baja17 1601 thinkin of doin back w...
 Tue Jun 09, 2009 04:27 PM
baja17 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Just aint firing. 2 joxracing 2484 Re: Just aint firing.
 Sun Aug 17, 2008 09:20 PM
