Latest: danmcfly
Overall: 3577
Visitors: 155
Total: 155
22: Event Calendar
28: Event Calendar
29: Event Calendar
59: Event Calendar
81: Event Calendar
91: News Letter
129: Event Calendar
133: Event Calendar
134: Event Calendar
136: Event Calendar
143: Event Calendar
146: Event Calendar
150: Baja Forums
151: Event Calendar
154: Baja Forums
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Question about Baja Bug Bumpers
carpe_cerveza
carpe_cerveza
Post Post subject: Question about Baja Bug Bumpers
Posted: Tue May 30, 2006 07:54 PM
Looking for general info on bumpers for Baja Bugs. I just bought a 1968 Baja that has no bumpers and want to fit it out so as not to damage the engine. So my questions run along the lines of... Are there different brands and if so does one stand out as best? Do they all mount the same (and universally)? Do I need a "heavy duty" type or is that just extra weight? Are they all skid plate compatable? Thanks for any info you can give me.
Post Post subject: Re: Question about Baja Bug Bumpers
Posted: Tue May 30, 2006 08:57 PM
Whatever bumpers you choose you will have to do some fabricating to get them to fit. There are basically two ways to mount rear bumpers, shock mount and firewall mount. I like the firewall mount better (they're stronger) but you will have to fab up some reinforcements. The shock mount bumpers mount to the top of the rear shocks, and are easier to install, but because they crimp the tube flat to make to mount to the shock bolt they tend to break.
Besides mounting points there are double and single tube bumpers. Simply put more material=more strength=more weight. I wouldn't worry about weight, the added strength outweighs (pun intended) any speed gains that you might get from the ten to fifteen pounds that you would save.
Every ting is skid plate compatible as long as you weld!!!
4 Admin_AzBaja 6063 Baja Bugs on Wiki need...
1568 mufasavnvmc 941726 Re: what did you do to...
285 MusicManiac 226969 Re: Baja sightings
0 Northmountainauto 891 Shop Baja
No new posts New Members Baja hiding in Chandler 9 Upsbaja 2647 Baja hiding in Chandle...
