Latest: strike77
Overall: 3575
Visitors: 120
Total: 120
26: Text Menu
29: Links
44: Event Calendar
48: Event Calendar
73: Pictures
76: My Account
96: Event Calendar
97: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- need help with picking a beetle
am i going to be able to get a baja out of one of these beetls?
yes
0% 0% 0%
 0%  [ 0 ]
no
0% 0% 0%
 0%  [ 0 ]
it will take alot of work, time and money
100% 100% 100%
 100%  [ 1 ]
Total Votes : 1
Post Post subject: Re: need help with picking a beetle
Posted: Thu Jun 14, 2007 10:39 PM
look at the front shocks if they are struts its a super, if they are just shocks , its a standard and a yes to buy!!
KrazyKarl
KrazyKarl
Posted: Sun Jun 17, 2007 02:15 AM
what year did super beetles start in, this one is 1957-60
Posted: Sun Jun 17, 2007 05:26 AM
wouldn,t be a super then.
Posted: Sun Jun 17, 2007 05:27 AM
i think in the 70,s not certen , look for the struts.
KrazyKarl
KrazyKarl
Posted: Mon Jun 18, 2007 02:06 AM
ok good. is the beetle to old to make into a baja, in terms of engine displacement and the gears and stuff. It wont be a syncro #1 but the other gears will be right?
Bubba
Bubba
Posted: Tue Jun 19, 2007 02:21 AM
I don't think it's too old! Twisted Evil
KrazyKarl
KrazyKarl
Posted: Thu Jun 21, 2007 10:23 PM
what about for engin size, i think it is only 1200 or 1300 cc
Bubba
Bubba
Posted: Thu Jun 21, 2007 11:17 PM
That's the beauty of a bug. You can put a 15 or 16 in very easily.
It's probably a 6 volt system though so you will need a voltage regulator, a light conversion kit, a starter and a new flywheel. All for 12 volts. Don't worry it sounds much worse than it is. Make sure you keep track of what year the engine and flywheel come from. (6 volt and 12 volt starters and flywheels have a different number of teeth.)
If you can't find a flywheel, a 6 volt starter and flywheel will work but, you can't crank the engine for long periods of time. Yes it will eventually burn up the starter, but it won't be right away. It will just crank faster.
Good luck!!!
KrazyKarl
KrazyKarl
Posted: Tue Jul 10, 2007 05:17 PM
thanks it sounds good. I also located a rolling floor pan, trans and all. Still working out a price. Its in great condition, no rust at all.
1 suburbangorilla 3104 CONVERTING '71 STOCK B...
 Wed Apr 01, 2015 11:51 AM
No new posts VW Volkswagen & Baja Bug General Discussion big beetle 3 bugzapper 2196 big beetle
 Wed Dec 17, 2014 06:07 AM
No new posts VW Volkswagen & Baja Bug General Discussion Lifting a super beetle front end 1 72sbbaja 1888 Re: Lifting a super be...
 Wed Jul 02, 2014 04:42 PM
No new posts VW Volkswagen & Baja Bug General Discussion super beetle baja bug 4 vtbaja 4477 Re: super beetle baja ...
 Wed Aug 14, 2013 04:48 AM
No new posts VW Volkswagen & Baja Bug General Discussion Super beetle vs standard baja kit 3 Voiden 2871 Super beetle vs standa...
 Thu Sep 13, 2012 07:35 AM
