Visitors: 108
Total: 108
11: Event Calendar
51: My Account
72: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Wheel Travel
Wheel Travel
GeneFrenkle
GeneFrenkle
Post Post subject: Wheel Travel
Posted: Tue May 01, 2007 06:20 AM
I've searched and cant' find this. Sorry if it is obvious information.
What is the wheel travel on the rear of a 73 bug (IRS)? I just put paddle tires on it and don't know if they will take off the fenders or not. I did cut the fenders.
Thanks.
1973 VW Bug
1776cc Motor
Post Post subject: Re: Wheel Travel
Posted: Tue May 01, 2007 10:38 AM
pull your shoch of the car and take a compress and a exteneded measure on it this will give you your travle, about 6" to 8" on a stock VW
GeneFrenkle
GeneFrenkle
Posted: Fri May 04, 2007 09:03 PM
6"-8", huh? I only have 5" between the new paddles and the fender. Man...I don't want to raise this.
1973 VW Bug
1776cc Motor
T_Town_Baja
T_Town_Baja
Posted: Fri May 04, 2007 11:03 PM
You have 5" between the tire and fender when its on the ground? That will not give you an accurate assessment. If you use the 8-9" travel base estimate, you will have to lift your baja off the ground and allow the suspension to fully droop, then measure. (Disregard if you have done this already)
Blaine
GeneFrenkle
GeneFrenkle
Posted: Fri May 04, 2007 11:45 PM
Oh...five inches would be from when it is jacked up????? That just might do it! Hurray! Very Happy
I have cut my rear fenders back a couple of inches since these pictures. It rubbed a little that day...but I was pretty easy on it.
1973 VW Bug
1776cc Motor
GeneFrenkle
GeneFrenkle
Posted: Fri May 04, 2007 11:46 PM
While we're at it...I have stock-sized tires on stock wheels. Would they be better on the front for sand than what I have on it?
1973 VW Bug
1776cc Motor
No new posts New Members Newbie from "florduh" here. Mid travel build. 9 shawn813 4706 Newbie from "florduh"...
 Thu Apr 18, 2013 11:13 PM
shawn813 View latest post
75 T_Town_Baja 99206 Re: Mid Travel Manx - ...
 Sat Dec 01, 2012 09:19 PM
jmert View latest post
No new posts VW Volkswagen & Baja Bug General Discussion wheel offset question? 0 billyjoejimbob33 2728 wheel offset question?
 Mon Oct 22, 2012 12:31 AM
billyjoejimbob33 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Wheel travel stock vs. 3x3 6 ghettodish 7190 Wheel travel stock vs....
 Tue Jan 31, 2012 02:57 AM
No new posts VW Volkswagen & Baja Bug General Discussion Travel- Delivery- Open trailers or truck beds?
Parts
0 catchbats 1884 Travel- Delivery- Open...
 Mon Oct 25, 2010 06:06 PM
catchbats View latest post
