Visitors: 150
Total: 150
27: Event Calendar
32: Event Calendar
37: Event Calendar
47: Event Calendar
72: Event Calendar
101: Event Calendar
116: Pictures
117: Event Calendar
126: Event Calendar
131: Event Calendar
150: Baja Forums
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- windshield replacement
soopercoop
soopercoop
Post Post subject: windshield replacement
Posted: Sun Apr 29, 2007 04:46 AM
Hey guys,
Any secrets to pulling front windshield and rear window and
replacing seals and re-installing?
Thanks,
Coop
Bahaw
Bahaw
Post Post subject: Re: windshield replacement
Posted: Sun Apr 29, 2007 06:37 AM
Lots of muscle & WD 40!!!
I cut out the old gaskets with a utility knife & removed the glass. After cleaning the glass, I had my daughter help by holding the new seal while I installed it onto the glass.
Then, a nylon cord was installed in the groove in the seal & three of us installed the windshield & rear glass after lubing the gasket & opening on the body with WD 40. Two held it in position and the other pulled the cord from the inside of the bug to install the gasket in the opening.
We also installed new seals in the 1/4 glass. The "Bad Bug" sure looks better with the new seals, but it was a lot of work!!!
I am tired again just thinking about it...
Posted: Sun Apr 29, 2007 07:01 AM
www.azbaja.com/windshi...nstall.htm
Posted: Sun Apr 29, 2007 03:43 PM
Make sure the nylon cord is 1/8 inch. It seems to work the best. Any bigger and its hard to pull through, any smaller and it tends to cut the rubber when you pull it. And do be afraid to hose the cord and rubber down the WD40, it all wipes off real easy with windex.
soopercoop
soopercoop
Posted: Mon Apr 30, 2007 04:30 AM
thanks guys, sounds like it'll be a blast.
Hope to have ready for paint in a couple
weeks. Neighbor just donated me his old
desert track tires and rims with about 1/3
still left on em' gotta love the freebies!
coop
No new posts VW Volkswagen & Baja Bug General Discussion fan belt replacement 0 azdesertrat87 2355 fan belt replacement
 Sat May 23, 2015 04:58 AM
No new posts VW Volkswagen & Baja Bug General Discussion Windshield wipers 4 Gunpilot 3727 Windshield wipers
 Mon Aug 08, 2011 06:52 AM
Gunpilot View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Alt belt replacement 4 Kinsman 2024 Re: Alt belt replaceme...
 Wed Apr 14, 2010 09:32 PM
Kinsman View latest post
No new posts VW Volkswagen & Baja Bug General Discussion looking for a convertible windshield frame ! 0 DRUMMOND 2154 looking for a converti...
 Fri Sep 26, 2008 04:54 PM
DRUMMOND View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Cargo area and heater ?tinnels? replacement. 4 WaBaja 2274 Re: Cargo area and hea...
 Wed Apr 16, 2008 11:30 PM
WaBaja View latest post
