Visitors: 130
Total: 130
34: Pictures
62: Event Calendar
123: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- cylinder 3 and 4+carb problems
zfriek42083
zfriek42083
Post Post subject: Re: cylinder 3 and 4+carb problems
Posted: Mon May 21, 2007 01:44 AM
I have the same problem only mine is the right side. I have done almost every thing you have done. except check compression cause i dont have a compression tester. I have a 40mm IDF Weber. that I pulled apart and througholy cleened adjusted the float. The carbs gotta be good. I adjusted all my valves. Checked spark and its sparking on all cylinders. I just cant seem to find the problem. Oh new spark plug wires and spark plugs.
Posted: Mon May 21, 2007 02:08 AM
Hi have you torque the heads.If the heads are not torque you will not get good compression. I hade the same problem in the past.It was a good fix.
No new posts VW Volkswagen & Baja Bug General Discussion Steering Box Problems 13 nukeworker 6886 Re: Steering Box Probl...
 Sun Jun 24, 2012 04:21 AM
nukeworker View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Carb Intake Covers 3 k-man 1709 Re: Carb Intake Covers
 Tue Jan 10, 2012 11:46 PM
Gunpilot View latest post
No new posts Projects and Builds carb troubles
1968 carb troubles
11 vwbajabug1 3692 carb troubles
 Mon Nov 15, 2010 02:12 AM
vwbajabug1 View latest post
No new posts Projects and Builds wanting 34 pict-3 carb
i need a carb
0 vwbajabug1 1378 wanting 34 pict-3 carb
 Tue Nov 09, 2010 12:07 AM
No new posts VW Volkswagen & Baja Bug General Discussion carb 9 luhrman645 3313 Re: carb
 Wed Aug 04, 2010 10:47 PM
