Latest: jor_dang420
Overall: 3597
Visitors: 83
Total: 83
18: Home
32: Event Calendar
45: Event Calendar
46: Event Calendar
47: Event Calendar
63: Event Calendar
78: Event Calendar
79: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- bleeding the master
bleeding the master
todd
todd
Post Post subject: bleeding the master
Posted: Tue Apr 17, 2007 02:21 AM
new master ,new hose,same lines..
so im going to blow out the lines and replace the hose..do i just fill the reservor and start bleeding from the furthest wheel cylinder
thanks
Post Post subject: Re: bleeding the master
Posted: Tue Apr 17, 2007 02:47 AM
You are correct, start with the right rear, then left rear, then right front then left front.
Posted: Tue Apr 17, 2007 03:07 AM
do a bench bleed on any new massa cyl's before installation.
todd
todd
Posted: Wed Apr 18, 2007 01:34 AM
o.k. so how do i do a bench bleed..
Posted: Wed Apr 18, 2007 03:55 AM
how much ya got to drink????? Razz
secure your massa on a table or other work surface.
remove the resevior cap
fill with brake fluid
use a long shaft screw driver or other impliment and push the cyl plunger in slowly. delay a second before releasing.
do this several times till bubbles stop comin out.
top off with fluid
cap off
install
find a helper.............ready? good!
the helper needs to depress the brake pedal and hold it. now connect the brake line (s). release the pedal.
go ahead and do a system bleed down all the way around just to be safe.
adjust the shoes too. Wink
planenutz
planenutz
Posted: Wed Apr 18, 2007 05:09 AM
Probably not a factor on bug cylinders, but if you push TOO far when bleeding it can mess up the seal on some newer m-cylinders. So Sad No! No! No! No!!!!
planenutz
planenutz
Posted: Wed Apr 18, 2007 05:15 AM
OH! I forgot.... When I would do the bench bleed I would plug the ports on the cylinder with my fingers before releasing the plunger so as to not pull air into the cylinder. There are also those that thread a piece of brake line into the cylinder ports, bend it up into the resevior so the end is under the fluid level, and then pump on it. Neutral
Posted: Wed Apr 18, 2007 06:21 AM
yea you can plug the ports. not sure if vw massas come with any plugs...
todd
todd
Posted: Sat Apr 21, 2007 11:09 PM
thanks guys im going to try it today...
GeneFrenkle
GeneFrenkle
Posted: Sat Apr 21, 2007 11:17 PM
I'm surprised Mykul did not jump on the title of this thread...
Bleeding the Master??
1973 VW Bug
1776cc Motor
