Latest: George
Overall: 3576
Visitors: 118
Total: 118
01: My Account
03: Home
15: Home
28: Home
37: Drivers
39: Event Calendar
44: Event Calendar
58: Pictures
60: Event Calendar
65: My Account
77: My Account
80: Event Calendar
82: Event Calendar
85: Event Calendar
95: Pictures
97: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- tire sunk in towrds bug
milleraj119
milleraj119
Post Post subject: tire sunk in towrds bug
Posted: Thu Mar 15, 2007 07:48 AM
went wheelin the other day nothin major just rallyin and donuts the usal then the steering wheel turnd to the right and i went into the bushes well i back out wondering what happen and i got out and my left tire was bend inwerds towrd the bug i was lookin at it and the bottom tube that connects to the bottom arm was out like 10 inched so i had to drive it home and i took the wheel off and hit it back in with a sluge hammer well i was wondering how it would just come out like that anyone no?? and i wasent wheelin that hard and also when i hit it the tube back in the passenger side bottom arm torsion leaf came out worndering how to get it back in hears the pic of it
anyone have any ideas??
milleraj119
milleraj119
Post Post subject: Re: tire sunk in towrds bug
Posted: Thu Mar 15, 2007 08:50 AM
help please
Posted: Thu Mar 15, 2007 09:00 AM
Bugzyla, Mykul, Don, or one of the other guys should be along tonight or tomorrow. sorry, I am still learnin also .
Posted: Thu Mar 15, 2007 01:35 PM
That is spring steal in that tube, you might of broken you sping pack, more than likly not... But you need to check all 3 locking bolts and recenter them you should have one in the midel and one on each end next to the trailing arm... unscrew all 3 and make sure the front end is off the ground as this is what holds it up Each sping pack has a dimple in them for the allen screw to hold them into place. Start on one side and get all the springs evan so you then bang them into the arm so you can see the dimple in the hole were the allen screw goes. once you see the dimple put the allen screw in and locker down with the lock nut. bang every thing into place and do the other side. then lock it all into place with the center allen. If you find your still having problems on the other side lock the center allen into place the try knocking it into place etc. If you still have bars sticking out you need to try again or you might have broken one of them.
Good luck and hope you can read this as I do not have my eyes in and it's 4:30am on my day off....
Posted: Thu Mar 15, 2007 05:01 PM
Check the set screw (grub screw) in the center of the beam, and also both ends. I also say you probably broke some springs.
Posted: Thu Mar 15, 2007 07:43 PM
To check if they are broken, remove the grub screws, pull 1 trailing arm out and remove the springs for inspection. To get them back in, clean them, grease them, stack them and tape them in the pattern tightly, then slide back in and reassemble the arms and grub screws.
No new posts VW Volkswagen & Baja Bug General Discussion Tire track width 4 cperry2704 2016 Tire track width
 Fri Dec 02, 2016 06:16 PM
No new posts VW Volkswagen & Baja Bug General Discussion Who's got a buddy at discout tire? 2 Ejbbal21 2531 Re: Who's got a buddy ...
 Sun Mar 25, 2012 02:43 AM
Ejbbal21 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion WATED: Wide 5 Aluminim Rim and Tire
Something like a Center line
1 DEDSLED2012 2297 WATED: Wide 5 Aluminim...
 Tue Mar 13, 2012 07:52 AM
No new posts VW Volkswagen & Baja Bug General Discussion NEWB with class 11 tire question
class 11 guys
2 icebox 6623 NEWB with class 11 tir...
 Fri Jan 06, 2012 05:38 AM
No new posts VW Volkswagen & Baja Bug General Discussion Need to borrow (2) 4-lug sotck wheel & tire set 2 fabinc 2462 Need to borrow (2) 4-l...
 Tue Jun 23, 2009 10:23 PM
danjones333 View latest post
