Visitors: 130
Total: 130
01: Home
84: Home
86: Event Calendar
121: My Account
1 2 3 ... 85 86 87 ... 103 104 105
Pointvirus
Pointvirus
Posted: Sun Jul 15, 2012 09:02 AM
Worked on my generator today. I have a 64 generator on my 68 so the wiring is different. I pinched the tip of my finger off with wire cutters trying to put pinch the connectors on the bolts. Just a temp thing to get my car running. She's been sitting for a while and she started right up! Now I'm sitting here at work until 7am and I'm cutting a stripped bolt out of my fan shroud so it will stop wobbling.
Posted: Sun Jul 15, 2012 05:24 PM
Ran the clutch and throttle cable lines on the rail and fixed the brakes on Project II by replacing the brake pedal.
Posted: Sun Jul 15, 2012 10:55 PM
New alternator installed and engine put together, just waiting on transmission.
Finished install of dash and "Oh Sh!t" bar for co-driver.
Finished up wiring for roof rack mounted lights.
NEED A WINDSHIELD for 1970 if anyone has a good on for cheap.
Hyperwrx
Hyperwrx
Posted: Mon Jul 16, 2012 04:03 AM
Began replacing stock boxed trailing arms with 3x3s. Stock boxed ones will be for sale shortly for cheap. They come with inner and outer stock CVs, drive flanges for 002, and all hardware.
Posted: Mon Jul 16, 2012 05:04 AM
Quote: "Began replacing stock boxed trailing arms with 3x3s. Stock boxed ones will be for sale shortly for cheap. They come with inner and outer stock CVs, drive flanges for 002, and all hardware."
Perfect for Dirtjunkies latest project. He has probably already PM'd you on these.
Hyperwrx
Hyperwrx
Posted: Mon Jul 16, 2012 05:44 AM
drums too!
Posted: Mon Jul 16, 2012 07:14 AM
Found and picked up replacement fenders for the front and heater boxes I plan on using asap! LOL They were in great shape, I don't think I've ever had heat in a VW. Smile
The fenders are probably going to be butchered, I think they were more for a street look. I don't really care, just as long as they are functional, don't rub and look the same.
Big thanks to Don! I made sure to mention AZBaja!
Posted: Mon Jul 16, 2012 08:27 AM
Tail lights are wired and all work. aka Done.
Lower Aluminum Radiator Hose is in place. Thanks JWH for getting then end welded up for me.
Went to the plumbing shop and got 5 1.5" copper fittings to do my upper radiator line. None of them were what I needed or backwards of what I needed. ended up going back and getting 1 45' Flange/No flange fitting. 1 90' Flange/Flange fitting and used the 1.5" to 1" reducer I had from the 1st trip. Did a few cuts with the Dremal to shorten 1 flange on to 90' by 1/2" and the matching Reducer by 1/2". Painted the pipe all black yesterday. The upper line is now done. Just need to clamp it in place next week.
At this point the engine should be ready to run. Just need to do final hook ups for electric fan and redo the fuel line/filter. Need to replace fuel filter that has end fightings to a filter that has a 90' input out put fittings. The filter puts a kink in the fuel line but a 90' input/output filter will fix that.
Now it is more painting on the inside of the car and remount the battery and box.
P.S. I'm working Sad summer vacation is over.
Hyperwrx
Hyperwrx
Posted: Tue Jul 17, 2012 03:10 AM
Swappin trailing arms
TrailRail2110
TrailRail2110
Posted: Tue Jul 17, 2012 03:21 PM
I snapped a Clutch cable and didn't have a spare with me this weekend, ordered two new cables from autozone and they will get here tommorow.
Posted: Wed Jul 18, 2012 12:00 AM
Installed all the hard and soft brake lines on Project " Willy Style"
Posted: Fri Jul 20, 2012 06:26 AM
A 68 is 12 volt and a 64 is 6 volt. Have you converted the 68 to all 6 volt? That would be very odd as the entire rest of the VW world has been converting 6 volt to 12 volt since the 1960s. Maybe the generator you got out of a 64 is a 12 volt after someone else converted it long ago?
Posted: Fri Jul 20, 2012 07:02 AM
washed the car this morning. got off work and took it out to take photos. finished shooting photos and decided to do some donuts in the dirt. clean car didn't even last a day and its dirty again. Smile
Posted: Sun Jul 22, 2012 05:06 AM
Radiator install is done, Just needs water. I need to Zip tie and loom a few more wires than the back of the car is done!!!
Now the front end Sad . Was going to hold out on working on it tell after the Pizza event. Wife and I went to bleed the brakes last night and all the brake fluid came out and onto the skid plate. Seems that the line for the resovior to the brakes is a 1/2" to short now...? Not sure how that has happend as it has been like that almost 20 years now. I need to go out and buy some new brake hose for the resovoir. And now that I have the car apart at that end I might as well do some paint and wiring too.
Posted: Mon Jul 23, 2012 11:54 PM
Hose must have shrunk. Shocked
Didn't you know you aren't supposed to leave the Baja in the drier on Hi?
Cool
4 Admin_AzBaja 6193 Baja Bugs on Wiki need...
285 MusicManiac 230016 Re: Baja sightings
No new posts VW Volkswagen & Baja Bug General Discussion Had to go play in the rain today! 3 azdesertrat87 419 Re: Had to go play in ...
0 Northmountainauto 1013 Shop Baja
No new posts New Members Baja hiding in Chandler 9 Upsbaja 2909 Baja hiding in Chandle...
