Latest: neal18
Overall: 3585
Visitors: 272
Total: 272
29: Pictures
33: My Account
34: My Account
35: My Account
54: My Account
57: My Account
60: Event Calendar
75: My Account
80: My Account
82: My Account
83: My Account
84: Pictures
87: My Account
141: My Account
145: Pictures
148: My Account
151: My Account
155: My Account
157: My Account
158: My Account
166: Event Calendar
171: Baja Forums
172: Baja Forums
176: Baja Forums
177: Baja Forums
185: Pictures
187: Pictures
188: Baja Forums
190: AMAZON.com
191: Pictures
192: Baja Forums
194: Baja Forums
195: Baja Forums
196: Baja Forums
197: Baja Forums
198: AMAZON.com
202: AMAZON.com
203: Baja Forums
204: AMAZON.com
205: Baja Forums
206: Baja Forums
207: Baja Forums
208: AMAZON.com
209: Baja Forums
210: Baja Forums
211: Baja Forums
212: AMAZON.com
213: AMAZON.com
214: AMAZON.com
216: Baja Forums
218: AMAZON.com
219: AMAZON.com
220: AMAZON.com
221: Baja Forums
223: Baja Forums
225: AMAZON.com
226: AMAZON.com
227: AMAZON.com
229: Baja Forums
230: Baja Forums
231: Baja Forums
232: Baja Forums
233: Baja Forums
234: Baja Forums
235: Event Calendar
236: AMAZON.com
237: AMAZON.com
238: Event Calendar
239: AMAZON.com
240: AMAZON.com
241: AMAZON.com
242: Baja Forums
243: Baja Forums
244: AMAZON.com
245: Baja Forums
246: Event Calendar
247: AMAZON.com
248: AMAZON.com
249: AMAZON.com
250: Baja Forums
251: AMAZON.com
252: Pictures
253: AMAZON.com
254: AMAZON.com
255: AMAZON.com
256: My Account
257: AMAZON.com
258: AMAZON.com
259: AMAZON.com
260: Baja Forums
261: AMAZON.com
262: AMAZON.com
263: Baja Forums
264: AMAZON.com
265: Baja Forums
266: AMAZON.com
267: AMAZON.com
268: AMAZON.com
269: My Account
270: AMAZON.com
271: AMAZON.com
272: AMAZON.com
1 2 3 ... 76 77 78 ... 103 104 105
Posted: Wed Feb 15, 2012 04:28 AM
Started building Biblethumpens motor, short block is together and pistons & cylinders are on.
Posted: Wed Feb 15, 2012 07:05 PM
1600 or are you going to bump it a few ccs?
Posted: Wed Feb 15, 2012 09:45 PM
Stock single port 1600, new bearings, crank polished, new rods, new rings, cylinders howned out with cross hatch pattern, rebuilt heads including new valve guides, seats and valves. High flow oil pump. Just going to build a nice stock motor for now.
DutchBug
DutchBug
Posted: Thu Feb 16, 2012 05:57 PM
Today I walked passed it...
Haven't been working on it for over a year. No money, no time.
I hope to move the body (it is already lifted from the bottom) this month and start to clean up some stuff.
Posted: Thu Feb 16, 2012 08:16 PM
I have a few will work for VW parts franchises still available. Smile
Posted: Sat Feb 18, 2012 02:49 AM
Worked on the Bugpack stinger exhaust last Sunday. Had to weld it together which sucked. I'm so out of practice welding. Took nearly the whole afternoon and still grinding/welding. No! No! No! No!!!!
I did get my High Lift jack and accessories this week. Woo-hoo! Cool
Posted: Sun Feb 19, 2012 02:52 AM
I degreased the tin and doghouse shroud and painted everything tonight. I'll drop the bug and painted tins off at Dirtjunkie's house tomorrow.
Posted: Sun Feb 19, 2012 03:08 AM
Replaced a generator that was going out, replaced a bent crank pulley, and put another exhaust on.
Posted: Sun Feb 19, 2012 03:46 AM
Just changed a broken clutch cable in Ted's Hot Dogs parking lot.
Posted: Mon Feb 20, 2012 06:12 AM
I returned an EMPI exhaust and just ordereda Tri-Mil Euro 2 tip exhaust and some rocker shaft shims.
Posted: Tue Feb 21, 2012 02:28 PM
Dirtjunkie's been busy. Its getting closer...
Posted: Wed Feb 22, 2012 10:21 AM
The las feww weeks I have been playing with Krylon Blue Spray Paint. Have been redoing the wiring in the Baja. Solder ends etc.
Kreed
Kreed
Posted: Wed Feb 22, 2012 03:49 PM
Discovered a brake line leak somewhere in the tunnel going to the rear wheels. Hitting the brakes and nothing... that is exciting!! Why couldn't the break be somewhere easy to see and fix.
Posted: Sat Feb 25, 2012 06:29 AM
Got the rail back on 4 wheels for the first time in a year.
Posted: Sat Feb 25, 2012 06:52 AM
I dropped off the last parts needed for Dirtjunkie to complete my engine this weekend. I'm excited. It looked clean and classy!
4 Admin_AzBaja 6710 Baja Bugs on Wiki need...
285 MusicManiac 240750 Re: Baja sightings
No new posts VW Volkswagen & Baja Bug General Discussion Had to go play in the rain today! 3 azdesertrat87 1253 Re: Had to go play in ...
0 Northmountainauto 1493 Shop Baja
No new posts New Members Baja hiding in Chandler 9 Upsbaja 4055 Baja hiding in Chandle...
