Visitors: 101
Total: 101
32: Event Calendar
34: Drivers
39: Event Calendar
64: Event Calendar
73: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- fuel gauge messed up
bajajon
bajajon
Post Post subject: fuel gauge messed up
Posted: Wed May 10, 2006 09:09 PM
ok when i bought my baja the guy told me the fuel gauge didnt work. well after i got it home and inspected, it wasnt hooked up. i hooked it up and it worked kinda, if i have a full tank it reads full but when i get down to a half tank it reads empty any ideas?
dang, I broke it again
Post Post subject: Re: fuel gauge messed up
Posted: Wed May 10, 2006 09:51 PM
you just have to get inside your tank and do some bending on the float sensor. Also you must rember that the stock vw gas tank is shaped like a "T" So once you get your fuel level down below the wide top area, the gas gauge will seem to drop faster.
Do you have a stock gauge or an after market? A stock VW gas guage will show 1/2 tank at 3/4 spot on the guage and a 1/4 tank at the middle of the sweep. See the fact the tank is "T" shaped above. So if you can find a stock guage cool, But if you have after market like my VDO 1/2 tank is realy a 1/4 tank left of fuel and once you get to the the last 1/4 tank of gas the guage will sweep real quick to the "R" or "E" as you will have about 2 gallons left.
Posted: Wed May 10, 2006 10:06 PM
I have run into this also. What can also happen is the little wire on the sending unit gets rubbed through and breaks about the half way mark from years of use. If this is the case you need to replace the sending unit.
You can get a new sending unit here.
www.dansperformancepar...yfuel1.htm
just scroll down to the bottom of the page. Yu probably ned the sending unit on the top right.
Posted: Thu May 11, 2006 02:37 AM
i dont have a fuel guage. i have a fuel dip stick. so sender or guage in 59 that i know of. Wink
69bapbaja
69bapbaja
Posted: Thu May 11, 2006 05:44 AM
dude, bap ... 20. bucks....
OWNER OF
Two Kats Tats
5030 W. Peoria
Glendale, AZ
85302
(623) 934- 9197
bajajon
bajajon
Posted: Thu May 11, 2006 02:01 PM
hey your the guy always taking all my money at bap, countryclub and broadway, i have that black baja beater baja, if you remeber Cool
69bapbaja
69bapbaja
Posted: Thu May 11, 2006 04:58 PM
hm black baja beater, sorry, face doesn't come up . I'm probley the one how takes all your moey all the time. I'm the BIG ugly one with the tan and black baja..
OWNER OF
Two Kats Tats
5030 W. Peoria
Glendale, AZ
85302
(623) 934- 9197
No new posts VW Volkswagen & Baja Bug General Discussion rack & pinion w/stock fuel tank 0 ghettodish 1955 rack & pinion w/stock ...
 Wed Nov 09, 2011 06:44 AM
ghettodish View latest post
Replacement Possible or Not
3 jemizasi 3755 1966 VW Beetle Fuel Se...
 Fri Apr 29, 2011 05:51 AM
No new posts VW Volkswagen & Baja Bug General Discussion Fuel pump failure 2 chickenpants 2064 Re: Fuel pump failure
 Mon Nov 02, 2009 06:57 PM
chickenpants View latest post
No new posts VW Volkswagen & Baja Bug General Discussion 12 gauge
15 jamesr6168 5209 12 gauge
 Sat Sep 19, 2009 04:00 AM
jamesr6168 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Fuel Filler Ideas? 4 catchbats 6558 Fuel Filler Ideas?
 Sat Jul 11, 2009 09:04 AM
57baja View latest post
