Latest: jor_dang420
Overall: 3597
Visitors: 79
Total: 79
12: Event Calendar
25: Home
46: Event Calendar
53: Event Calendar
54: Event Calendar
64: Event Calendar
68: Event Calendar
70: Pictures
78: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Help and advise for a 73' Super brake problem
scotter
scotter
Post Post subject: Help and advise for a 73' Super brake problem
Posted: Sat Jan 13, 2007 08:43 PM
Hey all,
I have run out of ideas. I have a 73 Super Bettle that sat for years. I have the motor running pretty good, but needs a little tweeking on the carb, all the electrical is almost done, new shocks,blahh blahh blahh. The point is I am ready to take it out on its madien voyage, but I can not get the breaks to bleed in the rear. I bought and installed a new master cyl, bench bled it and the started pumping the brakes. the front two are shooting oil like no tommorow, but i cannot get the back at all. they are dry as a bone. I followed the tubing all the way from the master to the wheel asembley and found no kinks or holes. There is no fulid leakage. I even tried to put some pressure on the system with the brake peddal compressed with a compressor to no avail. I would really like to do this myself, or with help but do not want to take it to a shop. I just am out of ideas on how to fix. Please give me a call or a note here on any other ideas.
Thanks
Scott
Crome wheels makes anything go faster!!
bajasam96
bajasam96
Post Post subject: Re: Help and advise for a 73' Super brake problem
Posted: Sat Jan 13, 2007 09:24 PM
With brake fluid being as hygroscopic as it is, meaning it absorbs water out of the air, you could have a line/rear brake cylinder completely plugged up with rust and corrosion. Not to unlikely if its sat for that long.
To find out for sure, disconnect a line at the front and rear and try to blow compressed air through it.
scotter
scotter
Posted: Sun Jan 14, 2007 08:06 PM
sam had it right on, the lines were VERY clogged. After taking the lines apart I found where they were cloged and baught new pieces. I hope to have her on the road today.
Thanks guys
1 LittleBaja 2421 Re: Brake Drum 4 to 5
 Sat Oct 03, 2015 04:52 AM
3 LittleBaja 2272 Re: Brake Drum 4 to 5
 Tue Sep 29, 2015 06:08 PM
No new posts VW Volkswagen & Baja Bug General Discussion Lifting a super beetle front end 1 72sbbaja 2357 Re: Lifting a super be...
 Wed Jul 02, 2014 04:42 PM
No new posts Projects and Builds my 72 super project 2 vtbaja 2993 my 72 super project
 Tue Jan 21, 2014 11:34 PM
No new posts VW Volkswagen & Baja Bug General Discussion Brake light switch?? 3 sandbuggy 3261 Re: Brake light switch...
 Sun Nov 17, 2013 08:21 PM
