Latest: rcwtony
Overall: 3607
Visitors: 94
Total: 94
01: Pictures
03: Event Calendar
24: Home
31: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Bolt on bumper
Bolt on bumper
yellowchev
yellowchev
Post Post subject: Re: Bolt on bumper
Posted: Sat Jan 28, 2017 02:28 AM
Dalton wrote:
I welded lag bolts to the backside of the mounting plates so I don't need to use a wrench on the inside of the car to get the bumper off. the 4 bolts on the mount are also welded to a 1" plate on the inside of the car and fit between the ribs of the fire wall... so I don't smash the stock firewall ribs.
Dalton, thanks for the info. You may have explained this, but does the diamond plate transfer the force from being rear ended back into the chassis? Or is it strong and thick enough to take on a rear end impact? I ultimately want to tie back into something structural so the forces are transferred correctly and not coming through the fire wall. I'll study your pictures some more to wrap my head around it. Thanks everyone for the input so far.
yellowchev
yellowchev
Posted: Sat Jan 28, 2017 02:34 AM
Dalton wrote:
Is the diamond plate missing here?
Post Post subject: Bolt on bumper
Posted: Sat Jan 28, 2017 03:50 AM
Yes, empi #9507. I had one on my car for years without issue before switching to a bus trans. I now run the bug to bus version and it's doing just fine
yellowchev
yellowchev
Posted: Sun Jan 29, 2017 05:51 PM
Awesome! Thanks I'll check it out.
Posted: Mon Jan 30, 2017 01:43 AM
yes... the diamond plate transfer the force from being rear ended back into the chassis it was thick enough... I built the bumper it to tow ... not to take an impact ... it seemed to do fine with no damage from being hit. if I get hit any harder it will start to do damage.... I think.. I did not build in a weak link for an impact... If I need to re-do the bumper I might build a weak link to save the body from damage.
yellowchev
yellowchev
Posted: Mon Jan 30, 2017 12:55 PM
Gotcha. Seems like a sturdy and good looking setup. I might mimick that just for the looks. What was the thickness of the plate again?
Does anyone have pics or could guide me to pics of what the bottom two mounts should look like? I'm lacking a visual on some of the instruction. In my mind it just inserts into the end of the pan where my strap transaxle extensions are. I'd like though to see what's correct and follow that as much as I can.
Posted: Tue Jan 31, 2017 12:01 AM
I went HD... don't like the store bought stuff. Check out the photos on my link... I used 3/4" all thread..
yellowchev
yellowchev
Posted: Tue Jan 31, 2017 12:37 AM
Awesome! I'll check it out
Posted: Tue Jan 31, 2017 01:35 AM
No new posts Projects and Builds Chickenpants' Bumper/Towbar 6 BugZyla.com 8464 Chickenpants' Bumper/T...
 Fri Feb 26, 2010 08:00 PM
BugLife View latest post
No new posts VW Volkswagen & Baja Bug General Discussion front bumper ideas 7 danjones333 5709 front bumper ideas
 Tue Feb 02, 2010 07:26 AM
NAXZ View latest post
No new posts VW Volkswagen & Baja Bug General Discussion new front bumper 13 danjones333 6689 new front bumper
 Sat Sep 05, 2009 11:11 PM
danjones333 View latest post
No new posts Projects and Builds How To Install New Rear Suspension Bumper in 69?? 4 glenf 3375 How To Install New Rea...
 Wed Jun 17, 2009 03:54 AM
glenf View latest post
No new posts VW Volkswagen & Baja Bug General Discussion front bumper 3 Dickie 3269 Re: front bumper
 Fri Nov 14, 2008 09:00 PM
jamesr6168 View latest post
