Latest: rcwtony
Overall: 3607
Visitors: 102
Total: 102
02: Event Calendar
26: Event Calendar
84: Event Calendar
90: Event Calendar
97: Event Calendar
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Tire track width
Tire track width
cperry2704
cperry2704
Post Post subject: Tire track width
Posted: Thu Dec 01, 2016 04:19 AM
I have a 66 baja, going to upgrade to irs and 3x3s...what size front beam will I have to go with to have tires run same track width? 6 over? 8 over?
Posted: Thu Dec 01, 2016 01:30 PM
I went 7" 3/4" so the welds did not hit the head ... I run 6" rear rims and 3 1/2 rims in the front ... the front tires track on the out side of the rear rims.
I ran a 6" over and my 700x15 hit the wheel wells bad. with the 7 3/4" they still hit but not as bad.
Posted: Thu Dec 01, 2016 01:33 PM
If I was not running AC in my car, I would push the beam out 3" ... it makes things fit better.
Posted: Thu Dec 01, 2016 03:53 PM
It depends on a lot more than just beam width. What size arms are you planning to run up front? What size wheels front and rear? Brakes? Etc...
I have a 6" over beam with stock arms, running 33 super diggers on 4" wide wheels. I run 3x3s in the rear with the same size tire and wheels and am almost perfect for track width front and rear.
Posted: Fri Dec 02, 2016 05:16 PM
my 67 was converted over the years from a swingaxle to IRS and the front beam have moved forward 2" over the years.
I have 3x3 rear. 1x1 arms on the front with a 8" wider beam. The beam is pushed forward 2" the moves the front tires forward 1".
I have 10" rims on the back and 6" rims on the front. Rims are reveres dished on both the front and back so center mas of tires are located better over the wheel bearings.
The front tires out side to out side are close to the same width as the back.
To be honest. You need to just get your tape and and do the math. That is the best way to figure it out.
No new posts Club AzBaja (Arizona Chapter) Run Your Car On The LUCAS OIL TRACK 8 wideopenmotorsports 6060 Run Your Car On The LU...
 Tue Dec 11, 2012 01:24 AM
No new posts VW Volkswagen & Baja Bug General Discussion Who's got a buddy at discout tire? 2 Ejbbal21 3422 Re: Who's got a buddy ...
 Sun Mar 25, 2012 02:43 AM
Ejbbal21 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion WATED: Wide 5 Aluminim Rim and Tire
Something like a Center line
1 DEDSLED2012 2815 WATED: Wide 5 Aluminim...
 Tue Mar 13, 2012 07:52 AM
No new posts VW Volkswagen & Baja Bug General Discussion NEWB with class 11 tire question
class 11 guys
2 icebox 9332 NEWB with class 11 tir...
 Fri Jan 06, 2012 04:38 AM
No new posts New Members 2011 Baja 1000 is live right now. Track it! 0 wideopenmotorsports 1739 2011 Baja 1000 is live...
 Sat Nov 19, 2011 02:58 AM
