Visitors: 138
Total: 138
03: Pictures
06: Home
28: Event Calendar
77: Event Calendar
79: Event Calendar
120: Event Calendar
124: Home
125: Home
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Tow Bar questions
Tow Bar questions
ghs215
ghs215
Post Post subject: Tow Bar questions
Posted: Sun Nov 15, 2015 06:53 AM
1) 66 bug, tow bar with 1 7/8 ball. When I tow this bug, it seems like there is a lot of slack in the system so when I'm pulling it, there is a lot of clunking and jerking going on. Is this normal?!?!
2) I was told that you cannot back up with these tow bars, it that true?
3) Where the tow bar connects to the axle, I notice that there is a bit of extra space and can slide each direction (just a bit). Is this OK? Should you grease this area?
Any other tips or tricks?
Thanks for the info!
Post Post subject: Re: Tow Bar questions
Posted: Sun Nov 15, 2015 02:44 PM
there will be some clunking and jerking. some worse than others.
Never ever back up any car that is being flat towed!! The VW bug Tow bar will Bend even if you back up a few inches.
When the tow bar is new it very tight and hard to put on as you use the tow bar it will bend an get loose to the point you will need to replace or repair it.
I never grease that area... sounds like it just make a mess. fokes that care about the paint on the beam don't tow bar there cars.
Always use a safety chains no matter how far you are towing.
lights are good. ... not having them will get you a ticket in some states.
putting up a "Car in Tow" in the back window ... just helps inform the really stupid people that the car behind you is not a tailgater.
ghs215
ghs215
Posted: Mon Nov 16, 2015 06:07 AM
Appreciate the info!
Posted: Mon Nov 16, 2015 01:45 PM
Oh.... almost forgot....
I always do this...
after everything is hooked up.. I always start the tow car and then get out of the car and turn the key just to the point that the motor turns off. then walk away.
I know of one VW bug and one VW thing that have exploded there motors by leaving them in first gear then towing them.
the Bug was not that bad when the motor went it locked up and they stopped right a way with little damage to the body..
the Thing on the other hand was a different story... I only saw picture of the damage but it looked like parts kept flying around in the back,,, beating the hell out of the back of the car.. most the block was gone. the . Part of the trans was gone. it was the most ugly thing I have ever seen... I would pay good money to see it blow up like that.
the thing was being pulled behind an RV... the driver never knew .
I think about that every time I flat tow my Baja behind my RV.
No new posts VW Volkswagen & Baja Bug General Discussion Considering buying a Baja Bug, but I have questions 4 AutomotiveDino 4763 Considering buying a B...
 Mon Jun 19, 2017 09:39 AM
daelan37 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Simple Questions- Wiring 7 camronbitzer 5556 Simple Questions- Wiri...
 Tue Jul 05, 2016 01:12 AM
No new posts New Members New Guy Questions 6 Apoc 4127 New Guy Questions
 Wed Jun 19, 2013 01:17 AM
Apoc View latest post
No new posts VW Volkswagen & Baja Bug General Discussion Outdoorsman Questions/Outback vs Squareback 10 Grunt-0341 8196 Re: Outdoorsman Questi...
 Sat Oct 27, 2012 07:07 AM
Grunt-0341 View latest post
No new posts VW Volkswagen & Baja Bug General Discussion First VW, Ides, Questions? 6 averyhutch 3943 First VW, Ides, Questi...
 Sat Apr 28, 2012 03:39 AM
crestfallen View latest post
