Visitors: 106
Total: 106
15: My Account
Baja Forums -:- VW Volkswagen Bug, Baja, Bus, Sandrail and Thing -:- VW Volkswagen & Baja Bug General Discussion -:- Got myself a 69
Got myself a 69
R0B_Z0MBIE
R0B_Z0MBIE
Post Post subject: Got myself a 69
Posted: Sat Feb 03, 2007 06:57 PM
I just bought a 69 baja. The engine is tired I'm not sure what size the motor is but it has SP heads which kinda threw me, any actually way check to see what size the motor is. Pictures to follow. Thanks
Post Post subject: Re: Got myself a 69
Posted: Thu Feb 08, 2007 03:23 PM
Only way to know for sure, is to pull the heads off and measure the bore. Being a SP, it will be a 1600 or smaller.
saltyslug
saltyslug
Posted: Thu Feb 08, 2007 09:17 PM
my 69 had sp engine also and they are usually the 1500. 69 is a good year, irs and dual spring plates, plus you can never go wrong with 69. i tell the girls mines a 69 even though its a 66, lol
saltyslug
saltyslug
Posted: Thu Feb 08, 2007 09:20 PM
also if its getting tired check the endplay on the pulley, and if its loose and you leak alot of oil you need to tear apart the bottom. if those thing are good then you ned to redo the top end new p/c's and freshen up the heads. get the slipin 1641's if you aint got alot of $$$. go blast that monster. good luck.
MontanaBaja
MontanaBaja
Posted: Fri Feb 09, 2007 01:31 AM
Sweet I Have a 68 baja, have fun with the baja
R0B_Z0MBIE
R0B_Z0MBIE
Posted: Sat Feb 10, 2007 03:02 PM
Shows you how much I know I thought anything after 67 were 12 volt systems with DP 1600 motors. And yes I believe in Santa Claus
Arizonateacher
Arizonateacher
Posted: Mon Feb 12, 2007 03:31 AM
I too have a 69 bug and I am not giving it up.
